Where is the lever in the adf on a muratec mfx3530
Mfx 3530 is showing that there is a paper jam there is a lever that needs to be adjusted for it to read there is no paper jam, where is that lever
doc_delphi
  • 11 Answers
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
  • 5 Answers
SOURCE: MFX -2380 (Muratec) issue with net work printing
In network environments the muratec's usually have to have the setup disk run. They do not work on the standard TCP/IP port. The disk creates a muratec port for the pc to print to.
Posted on Jan 19, 2009
20YrsCompExp
  • 227 Answers
SOURCE: need to know how to enter service mode on muratec mfx-2830
Do you mean Service CODES or Service Program MODES? Do you realize that there are almost 800 - 900 service codes and or program modes.... you would do better searching for a service manual for that machine, that will list the codes with explainations and program modes and what they affect when changed.
Posted on Apr 03, 2009
  • 1218 Answers
SOURCE: reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Posted on May 27, 2010
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
epson artisan 800 keeps saying "paper jam" but there is none.
HELP!!!
Posted on Jun 01, 2010
Printer keep saying paper jam
The most common cause is the green paper guide in the paper cassette is pushed towards the paper too much. I am referring to the large one right in front as you open the tray. Move it out towards the front a bit, lessening the pressure that it is applying to the paper.
Oct 12, 2013 | Muratec Mfx-2550 mfx-2550
Document feeder reporting paper jam when there is nojam
The ADF need to be serviced the sensors are detecting the jam which you can not see.
1. maybe there is a very tine piece of paper inside therefore, service it.
2. there is a cover containing some switches which complete the circuit for the the cover may be it is not fully closed. (close it)
3. position the sensors nicely and properly.
4. replace the PCB for the ADF
5. Disconnect the ADF from the machine main PCB.(repair it), the machine can work without it being connected.
Jul 13, 2011 | Muratec MFX-2000 Plain Paper Laser Fax
Our Muratec MFX1430, ADF will not feed mulitple copies at times and when it does only the first couple pages are printed in full with the other pages only printed on half of the paper. Also, the left...
Yes...contact a copier dealer who also sells Muratec...most likely that the broken Left hinge on the ADF is the cause of your feeding problems....probably about $25.00...the part in the paper tray Don't know..never had anyone break one.
If you cant find a dealer have a look on Muratecs web site for a contact #...their web site is www.muratec.com
Mar 09, 2011 | Muratec MFX-1430 Copier
The MFX2830 adf pulls the paper crooked when feeding.
check ADF rollers and re-feed pads.(maint cycle approx.50~80K)
Also check ADF is square on copier..sometimes people push on ADF when moving machine and get ADF out of alignment.
Mar 03, 2010 | Muratec MFX-2830 Black and White Copier
Where can i find document rollers for document feeder?
document rollers is located immediately beside entering the paper or on paper if you use presenting with pallet
Oct 08, 2009 | Muratec MFX-1430 Copier
Muretec mfx 1430 streaking through the adf and its not the **** glass. Off the glass looks fine have swamped out the whole feeder twice same problem.
Hello sir; Let's try two things , 1st, make a copy go through by ADF. 2nd, make another copy direct from the glass. if 1st one coming out with streak line that's mean on the left hand side of the plateform have a piece long strip glass need to clean.
if streak line coming out from 2nd copy that's mean you need to replace drum cleaning blade.
Mar 13, 2009 | Muratec MFX-1430 Copier
Muratec MFX-1300
Underneath the ADF in the front left hand corner you will see a small plunger...you should be able to push it in with your finger( it is spring loaded so will come back out ) this plunger operates a sensor inside the ADF when you close the ADF/LID to tell the machine it is closed.
Check that the plunger is working...if it is then the sensor inside may be faulty.
Sep 17, 2008 | Muratec Copier
Muratec MFX 2500 copies have lines
need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Muratec mfx-2000 error problems
please check the switch of mentioned cover may be it is abnormal or open and close the front cover or check may be there is one reset switch in your machine
Sep 26, 2007 | Muratec Copier
32 people viewed this question
jasbo
jasbo
