Question about Goodman Heating & Cooling
Age of goodman condensor serial #9912243051
How to determine the age of this Goodman condenser from serial #9912243051? thx.
    Genius:
  • Goodman Master
  • 1,363 Answers
Mfg date december 1999.
Posted on Aug 09, 2015
garing
  • 998 Answers
SOURCE: Goodman a/c condsensor doesn't return freon to unit
may be low or blocked
Posted on Aug 31, 2009
  • 232 Answers
SOURCE: Need to determine year of Manufacture for Goodman
first two are the year and next two are the month ie 0106..... june 2001
Posted on Sep 19, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Goodman CK49-1L, and the condensor just
Your compressor is pulling high amps... it is locked up and cannot turn...it will need to be replaced...
You can check the capacitor to make sure that it is not the problem, but usually it will be the compressor...
heatman101
Posted on Apr 20, 2010
  • 57 Answers
SOURCE: How do I open the goodman condensing unit for cleaning
I suggest taking the top screen and possibly the condenser motor out. If you try to take off the cage that surrounds the unit, you may not get it back on right. Best to push the dirt out with a hose from the inside out.
Posted on Jul 16, 2010
  • 674 Answers
SOURCE: Replacing a Rheem Heat Pump
The difference is that the reversing valve is energized it heat mode for one brand and energized in the cooling mode for the other brand. An "O" on the circuit board indicates energized in cooling and a "B" on the circuit board indicates energized in heating.
Posted on Sep 09, 2010
WHERE IS THE Goodman GSZ130301 RESET BUTTON ON CONDENSOR
No reset button. As for low/high pressure switches they reset on their own when the problem is corrected. Usually low refrigerant.
May 03, 2014 | Goodman Manufacturing Goodman GSZ130301...
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
Is there a uniform way of reading the serial numbers of all mfrs of A/Cs. Our warranty company needs to quickly establish the age of a A/C unit at the point of claim to determine how much we can authorize...
Unfortunately, no. Each manufacturer has their own coding system for serial numbers. Which to them reveals many things about the unit, regardless of the Model Number. Only Goodman can tell you that. If you live in the USA contact Goodman Residential Customer Support @ 1-877-254-4729.
I really hope this helps you. Please let me know and thanks for choosing FixYa.
Aug 11, 2011 | Goodman GMS90703BXA Heater
Hello, i have a 3 ton 10 seer goodman condensor. It is blowing the circuit breakers, sparks came from breaker box, unit is 11 years old. Can you help?
If you had sparks in your breaker box then you need to call an electrician to look into that. If the a/c is blowing the breaker you may have a shorted compressor and will have to replace it or the whole condensing unit, depends on the price of the compressor vs a new condenser.
Jun 18, 2011 | Goodman CLQ36AR49 Air Conditioner
Jul 15, 2010 | Amana Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
