Question about Sanyo Televison & Video
My PLV-55WHD1's power light blinks RED EEEK
My PLV-55WHD1's power light blinks green like normal and then steady green like normal and then it will blink red... no picture no nothing...
  • 1694 Answers
SOURCE: No picture or sound - Power Save light blinks red 5 times - nothing on the screen
Best first step = change lamp
Posted on Oct 24, 2007
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Feb 20, 2008
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
SOURCE: Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Posted on Mar 20, 2010
Red light blinking green light steady on
THIS IS A NORMAL THING FOR UNIT TO DO
GREEN IS POWER APPLIED
AND RED IS HARDDRIVE RECORDING VIDEO DOWN
Mar 07, 2014 | Lorex LH118501C4 8 Channel 500 GB DVR with...
Sanyo PLV-55WHD1 picture too dark
It may be the lamp itself, some will dim just before failing.
Average life is 2000 hours or two years for OEM lamps and much less for generic ones.
Dec 22, 2012 | Sanyo PLV-55WHD1, PLV-65WHD1 Projection TV...
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
We have a Sanyo PLV-55whd1. We have replaced several lamp bulbs because blew shortly after we put them in. We then replaced the lamp ballast and the TV was working for a few days. Now the Power Light...
You have to pull the chassis out and it sits on top. Also there are 2 squirrel cage fans that cool the bulb, be sure to blow these out, especially the supply fan, its gets caked up really bad and then there no air to the bulb which makes the thermal switch trip. Theres also two other computer type fans a larger on which is out in the open on the right side and a smaller on on the left as viewed from the rear of the TV. The small one is burried, you will need to pull the tuner to get a good crack at it.
May 01, 2011 | Sanyo PLC XU30 Multimedia Projector
Looking for replacement lamp for Sanyo PLV-WHD1 TV Lamp type # POA-LMP96 service parts # 6103227382. Need some help finding one that is compatible for reasonable price.
You can get replacment lamps for this TV from www.TvRepairKits.com
Models Supported = PLV-55WHD1, PLV-65WHD1, PLV55WHD1, PLV65WHD1 ,PLV-55WR2C, PLV-55WR2CH POALMP96 , POA-LMP96 , 6103227382. and more.
Feb 03, 2011 | Sanyo Genuine Original 6103227382 ...
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
Looking for a POA-LMP76A lamp and price
Call Encompass Parts 1-800-638-3328 and Look on E-Bay under Electronics.
Feb 14, 2010 | Televison & Video
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Televison & Video Logo
90 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
