Question about Bauknecht 24 in. GSFP3988 Built-in Dishwasher
11flashes on bauknecht dishwasher
Water flows out
Display showing f4 what does that mean thank you julie
Hello
Fault with water fill (only on machines with level-controlled fill)
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
Aug 21, 2011 | Bauknecht 24 in. GSF8971 Built-in...
Hi, on my WAE8987 Washing machine, the fault code 'F07' keeps coming up, can anyone help please? thanks
Bauknecht are built by Whirlpool.
F7 on Whirlpool means flow meter failure.
Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
To reset try turning on the power and holding the start button and the + and - buttons at the same time.
Dec 01, 2009 | Bauknecht Dishwashers
Water left in machine, not emptying, light flashing
you may have an inefficient or partially blocked water pump remove drain hose and check if there is an obstruction if so clear it and re attach hose try draining machine listen to water flow if strong ok if not you still have an obstruction or faulty pump if no flow at all pump or control failed on final drain hope this assist you
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Hi my Bauknecht GSI 5411 dishwasher seems to starting ok but then it stops after a couple of minutes. have checked the water supply tap as well as the filter and they seem to be ok. Please help
Set the machine to the end of the drying cycle, when it has finished, try pouring boiling water into the machine about a kettle full there is a sump level control beneath the removable filter (where all the **** gathers) if this has fat deposits on it this type of problem can occur.
Dishwasher will not fill. Water lines have been checked and filters are clean
Flow detection shot?
Expensive one I had couple of months ago on a Bauknecht. 300 dollars. New machine at 250. Scrapped it.
Flow detector was coupled at automatic waterstop.
Beware if you have a old machine drying with hot air, most all new models use condensation leaving your dishes etc a bit bit wet :(
Apr 14, 2009 | Dishwashers
Bauknecht GF7199 F7 light has come on
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Hope this helps .
Mar 06, 2009 | Bauknecht Dishwashers
Dishwasher
have only worked on them a few times but no problem to use. literally select program, close door and start. you won't break anything by trying it out.
put detergent in the dispensor and rinse aid in the rinseaidv despensor. if in a harrd water area, add dishwasher salt to the softener
Aug 14, 2008 | Bauknecht 24 in. GSF8971 Built-in...
Have got a bauknecht dishwasher model no gcx 5521. had the same problem last year. water is not going into the machine it looks like the water stop device activated. I think its something to do with a...
have got a bauknecht gsx4756 which when started beeps continually and start light flashes. it automaticaly then flashes the rinse button as well. I have reset holding down start and mode selection button next to the start button the fault keeps recurring. just wanting to know what the problem is before paying an engineers extortionate call out fees
Jul 31, 2008 | Bauknecht Dishwashers
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Bauknecht 24 in. GSFP3988 Built-in Dishwasher Logo
16 people viewed this question
Top Bauknecht Dishwashers Experts
Andrew Taylor
Andrew Taylor
Kevin Getz
Kevin Getz
ray gallant
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
