Question about Lowrance LGC-2000 GPS Unit GPS Receiver
LGC-2000 Error message "GPS Module Not Responding"
I've had this problem for 3 of 4 years. Lowrance support was no help just sold me a new antenna, which eventually had the same problem. Fix, is to buy a Garmin.
5 Suggested Answers
SOURCE: lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Posted on May 08, 2008
SOURCE: Lowrance LCX-15MT Ihave used this
Go to lowrance's website and run through their set up tutorial / instructions for the unit, there is also a software upgrade you can do online for the unit.
Posted on Oct 10, 2008
  • 30 Answers
SOURCE: lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Posted on Jul 11, 2009
SOURCE: lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Posted on Jan 12, 2011
Lowrance 330c gps not responding
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
I have a lcx16 sounder gps with a lgc12s antenna receiver. The gps module is not responding Do I need a new antenna ?
more than likely you do or you have a bad connection. It's always best to take this sort of issue to a shop in the event something is wrong with the unit itself before buying the new gps.
Jan 19, 2010 | Lowrance LGC-12S GPS Receiver GPS Receiver
The GPS claims that the transponder is not communicating. All cabling looks fine and there is no apparent damage to the head.
Normally this error shows that something is wrong with the antenna itself. If the unit is old it's best to change it out. most gps antennas are only good for about 5-10 years. unless you have had a lightning strike close by then less. The other thing is to make sure that you don't have the internal gps selected in the menu and that you have both terminators on the nmea 2000 network that the LGC-2000 is connected to.
Oct 29, 2009 | Lowrance LGC-2000 GPS Unit GPS Receiver
Every time i turn on my lowrance 520c it says gps module not resp
I had the same problem. Sent my entire unit back to Lowrance, but they said it was fine. One year later, I find out that I did not receive or have the correct parts to hook up the GPS unit. I needed the NMEA 2000 T connector and terminator plugs. Look at your manual and hook it up the way the manual says. It will require a NMEA 2000 T and at least one 60 ohm terminator plug. Seems the GPS module sends back some kind of signal that if not absorbed by this thing will mess up your unit. Mine works since I got it hooked up correctly. HD
Jul 17, 2009 | Lowrance LGC-3000 GPS ANTENNA FOR UNITS...
Lcx-15ct (gps module not responding)
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
Lowrance LCX-15MT Ihave used this unit as a echo sounder from new just purchased LGC 12w arial to use GPS as well but keeps coming up(GPS module not responding)
Sep 09, 2008 | Lowrance GPS
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
I just bought a lgc 2000 antenna for my lcx 20 lowrance. i haven't any manual but the seller said all i had to do was plug it in. well, all i get is" gps module not responding".is there something...
hi the lgc has to be powered also with the nmea cable,red to+,black and shield to-,you also need a 60ohm terminator atached to the short length coming from the y piece,the manual does not state this very clear and lowrance is not much help
Apr 28, 2008 | Lowrance GPS
Gps module
I just went through this with Lowrance. tthe LGC 2000 module on my LCX 20 depth finder "quit responding" out of the clear blue. You have to go Lowrance.com and they have some tests you can follow to see if it is a bad cable or the module itself. I had to replace the module. They charged $99 bucks plus $12.50 shipping for a new one. I bought it spring of 2008, and the unit was 3 months out of warranty when it quit working. Last season I had lower back fusion and didn't use it except for 2 times late in the season. Getting ahold of Lowrance is going to be an experience. I called twice and waited on hold over 35 minutes before I was suddenly cut off both times. I tried email too, but it took 3-5 days to receive a response. Mine broke down June 18 of this year. I started trying to get hold of Lowrance the next day. By the time all the back and forth emails with the delayed responses were done, I received my new unit on July 24. 5 weeks! with out my gps in MN. It is a short season up here as it is. I sure didn't enjoy waiting that long.
Oct 19, 2007 | Lowrance LGC-2000 GPS Unit GPS Receiver
Lowrance LGC-2000 GPS Unit GPS Receiver Logo
217 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
