Question about Pentax 645N Medium Format Camera
Pentax 645 viewfinder went dark after previously working fine
I was able to see through the viewfinder fine after recieving it in the mail and then after taking off the film carrier and replacing it, the viewfinder went very dark. I didn't change anything. Is there any way that I can fix this myself and I'm just making a silly mistake? The eye piece is also very loose. Thanks!
  • 185 Answers
SOURCE: Pentax SF1
This model has a gear train from the motor to the advance sprocket. The gears are plastic and prone to strip. Try E-Bay for a reasonable replacement and keep this one for parts. There are no new parts available.
Posted on Dec 08, 2008
  • 185 Answers
SOURCE: Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Posted on Dec 27, 2008
mail541
  • 58 Answers
SOURCE: Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Posted on Jan 21, 2009
mail541
  • 58 Answers
SOURCE: How to open Top-plate of Pentax MG
Sounds like the pressure plate for the viewfinder lens has dropped in front of the lens. If the viewfinder surround is craked this is very likley.
To learn how to remove the top of these cameras and other Pentax's there is a camera repair website where you are shown how to do this. Just click the link.
mail541
  • 58 Answers
SOURCE: Pentax A3000 frame advance jammed
There could be a number of causes.
First make sure that the replacement batteries are up to it. Ie one's marketed for camera use. Others often cannot supply the current required by the motors. (Electric motors require most current just as they start, and so it may not do anthyhing at all.) Then check the battery contacts are clean. Much the same reason applies, dirty contacts cam prevent the batteries from supplying enough current.
One more simple possibility is that it does not know the battery door is closed. This may be detected by a protrusion in the film door edge operating a contact in the loctaing groove, or contacts in the door latch. There may be more than one!
It is also possible that the camera is detecting an impossible film. DX coded film uses the contacts inside the film chamber to read the film speed from unpainted sections of the film cassette. It is just possible that a dirty contact or a scratch in the paint is telling the camera that the film is a speed it cannot handle, or is just confusing it with a nonesense code!
Outside these there are a number of possibilites which will require internal investigation. You can try these camera repair pages for tips on repairing your own camera.
Posted on Jan 23, 2009
My E 300 works fine with the 14-45 3.5-5.6 lens, bright viewfinder and good photos. However, with the 40-150 3.5-4.5 lens the viewfinder went dark abd photos are overexposed. Problem went back and forth...
I assume this happens while your camera is in the automatic mode. Because if the camera is in manual, you can't assume both lenses give the same light to the sensor.
But I should look if the contacts on the lens and in the camera, ale all clean and shiny. And not one of the contacts is allowed a dent. Not even a little dent. All contacts must be flexible. Then be sure the Aperture setting on the 40-150 must be correct. The camera manual does not say a thing about the settings on the lens, but I should look there too.
Feb 19, 2014 | Olympus EVOLT E-300 (Double Lens Kit)...
Viewfinder is dark until picture is taken.
Have you tried pressing the display button ? It should switch from LCD to viewfinder.
Jan 26, 2013 | Canon PowerShot G2 Digital Camera
I have just started using my husband Pentax K100D camera. The viewfinder seems really dark. My camers is a Fujifilm S5700 that seems to have a lighted viewfinder. Is there any way to make the viewfinder...
The best way to lighten the viewfinder is to purchase a new focusing screen. There are many alternatives available and usually cost around $100. There are specialty screens to allow better manual focusing and others that brighten the viewfinder. These effects are usually achieved through coatings on the screen. They are relatively simple to install, however if you are uncomfortable doing it yourself, a local camera shop should be able to do it in a matter of minutes.
This screen will allow better focusing of manual lenses and will also brighten the viewfinder, when you purchase the "Brightness enhancement treatment" option at the bottom of the page. http://www.katzeyeoptics.com/item--Pentax-K100D-K110D-K200D-K-r-K-x-Focusing-Screen--prod_K100D.html
The linked product also fits your camera, and the brand is highly regarded as being good quality. There are other options available though, simply search on B&H Photo Video or Adorama Camera. They have many different options.
B&H:http://www.bhphotovideo.com/c/search?Ntt=k100d+focusing+screen&N=0&InitialSearch=yes Adorama:http://www.adorama.com/SearchSite/Default.aspx?searchinfo=focusing+screen&category=4294962858
Thank you for choosing FixYa!
Feb 01, 2011 | Pentax K100D Digital Camera
Got a pentax 645 at a yard sale but no instructions
You can find a manual at http://www.butkus.org/chinon/pentax.htm
Apr 09, 2009 | Pentax SMCP-A 645 150mm f/3.5 Lens
Pentax K200D NO LCD just viewfinder visual
Pentax K200D is a SLR Digital Camera..... in SLR you can the images in LCD after it has been taken.... while cliking image you need to use the Viewfinder......
Mar 24, 2009 | Pentax K200D Body only Digital Camera
Nov 23, 2008 | Pentax ME Super 35mm SLR Camera
Sony TRV 245E
I wanna know its model number, is it DCR-TRV245E or some thing else..?
Aug 16, 2008 | Sony Handycam CCD-TR818 Camcorder
Sky+ satallite receiver
You can find out if the remote is broken by taking a camera4.gif with an LCD viewfinder (such as a camera phone1.gif) in a dark room, point the remote at the camera and in the viewfinder you will see a light coming from the remote if it is working. If you see a light, chances are the remote is good. If not then the remote is more than likely bad.
Jan 13, 2008 | Televison & Video
Viewfinder
I don't know how to answer your question, since I haven't yet experienced that phenomenon. It sounds like it's just caused by the nature of the lenses used. Since you are new to the camera, I'll just warn you that it is not perfect in any way, but every function of it is very good, so the end result is amazing, and I might even say perfect. This is just the nature of the Pentax dSLR for now, and it seems that it's a Pentax thing in general. You'll find lots of dSLRs that can outperform the Pentax in one or two feature comparison tests, but if you lign up all the features of one camera and compare them with the Pentax you'll find the Pentax will beat any camera out there. It is just so well balanced, and each feature really is good enough, which adds up to a LOT. I'm sure somebody here will explain the problem you're having, and if you're like me you'll just make a few adjustments and be satisfied with the results. Post some shots too, that's an excellent way of getting feedback that will help you make the most of your Pentax. I wouldn't trade my Ds for any other camera out there even costing 10 times more.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Pentax 645N Medium Format Camera Logo
42 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
