Question about BOSS AUDIO SYSTEMS Car Audio & Video
Boss bv9.2 cbl. not playing disc
Error diec
I have a boss bv9973 in -dash 7" flip stereo and it won't read disc, I put disc in it just flashes disc on screen and doesn't start disc
I've heard something about an extra screw being present and preventing it from playing and to take the screwnout.
Feb 05, 2016 | Boss Car Audio & Video
My Boss br-8 keeps saying medium error. It's not reading any disc. It ask me to initialize disc that already have music on them.
If the disk had music that was not CREATED on the BR-8 you will get the error. The format is incompatible with computer formats.
If the files were created on the same BR-8, then you probably have a disk drive failure.
Try initializing a blank disk. If it will not, then you have a drive failure.
Also is it possible you are trying to read a 250Mb disk on a 100Mb drive? That won't work either.
Jul 25, 2010 | Boss Micro BR Digital Recorder
My HTR-6060 plays through the tuner and dvd but not the DTV/CBL
Digital settings need to be assigned by the receiver in the ption Menu >> Audio Select.
Check the one for the HDMI from DTV/CBL.
May 23, 2010 | Yamaha HTR-6060
Would not play anything
If this is happening to all the discs you insert then you are having a problem with the laser lens. If the lens is faulty then you wont have any success. Replace the unit or if you want to really invest in the repair then go ahead and do so but im personally not to crazy about boss car audio equipment, quality is poor and chances are that it will happen again. Good luck boss.... : )
Mar 10, 2010 | Boss AUDIO SYSTEMS BV7300 Car DVD Player
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
My boss cd player would not play any cd,it keep saying check disc
Try a disc cleaner if that doesn't work the unit will need to be repaired
Jun 19, 2009 | Boss CD-3025R CD Player
Disc loads, but won't play
Are these factory DVD's? Or burned ones? Als, are you loading te disc correctly. I have a PowerAcoustic and the DVD MUST be loadedupside down.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Boss DVD-7500 Car DVD Player
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
Boss Marine CD player
It could mean many things: the disc is inserted upside down, the disc is too scratched to play, too dirty to play, there might be condensation on the lens, mechanical failure, the list goes on. If the disc is fine and inserted the correct way, and the error code keeps appearing, it typically indicates mechanical failure and that the CD player will need new parts and/or alignment to properly work again. I would suggest taking it to an authorized repair center.
May 07, 2006 | Boss Audio MR1500 In-Dash Marine CD...
Car Audio & Video Logo
27 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
