Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
HOTPOINT BFI620 one led flash error
Hi, as soon as i turn on the machine, it seems like the programme get stuck. won't reset, and the pump is constant running. i have one led flashing!!. sometimes on power up , no leds are lit. also, had experienced four leds dim lit.
please help (wife will kill me)
  • ellaway Mar 21, 2008
    I also have the same problem. The house trip switches went which after investigation was down to the dishwasher. Now although it all seems to function, when the programme starts it sounds as if the pump is working but no water is coming through.
  • 868 Answers
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
  • 2 more comments
  • Huw Evans Dec 11, 2010
    I had exactly the same symptoms with my Hotpoint integrated dishwasher BFI620 with one led flashing as fault error code on (the left hand intensive heavy duty cycle / intensive wash light). The fault was that the floor of the carcass had filled with water from a leak and activated the float switch. Shut the door, remove kitchen pinth and then the 2 black access plates that you can now see below the door. Look inside and carefully feel the floor of the housing to see if it's wet. Ours was leaking due a loose nut under the lower spray arm but I had to stand it on an elevated surface and run it with the floor removed to find the leak. You can disconnect the switch to do this but be careful as most wires inside are mains voltage.
  • Huw Evans Jan 21, 2012
    Just had the floor of the BFI620 fill with water again so that the dishwasher does not start: the pump just runs but it does not fill with water. This time I traced the leak to the water flow control conttol tank behinnd the left hand side panel: one of the hose clips was allowing it to leak. Also, the bottom of the dishwasher used to fill with water when off: I traced that to a dodgy water inlet valve, which I replaced with one from an indest washing machine as it was cheaper and practicall identical. Rubbish dishwasher!
  • keith_turnbu
    keith_turnbu May 07, 2012
    My symptoms were similar - left LED flashing, pump running constantly. I checked for water on the carcass floor and this turned out to be the problem as Huw suggested. Some kitchen tool soaked up the excess water and my dishwasher is restored to health. Don't forget to turn off the power! And many thanks Huw - saved me a considerable amount of money!
  • Huw Evans Sep 05, 2013
    If your dishwasher stops working and the pump is constantly running and won't start the washing cycle, then the problem is likely to be a leak which has caused the bottom of the carcass to flood with water and trip the microswitch. I have had this happen 3 times on my BFI620. The first time it was a loose nut on either the bottom spray arm or the salt container. The second time it was a leaking hose clip on the flow control tank mounted under the left side panel. The third time it was due to a perished elblow joint where the waste pipe / drain hose fits onto the pump. If the interior of your dishwasher fills with clean water then, as mentioned above, it's a dodgy water inlet valve. These dishwashers are rubbish and I'm fed up of taking it out, which is no mean feat for a integrated dishwasher. You are able to determine if there's water on the floor of the carcass before you remove it by taking off the skirting board / vanity panel and removing one of the black covers. Then feel downwards inside to see if the bottom floor is wet. Just drying the carcass floor as Keith suggests (above) won't fix the underlying leak.
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
Jul 15, 2017 | Hotpoint Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Aug 15, 2015 | AEG Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
1,558 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
