Question about Azend Group RH-200-3 - A4tech Rh-200-1 Wl Rechargeable
Damaged usb receiver
I had a damaged usb receiver and also the soft pads were damaged
How do I clean some burned on grease from the non-stick surfact
Villaware might be able to offer some advice but, in general, damaged non-stick surfaces require recoating which can be an expensive process.
Nov 29, 2014 | VillaWare Kitchen Appliances - Others
I replaced the rear pads and rotors.I screwed the pistons all the way in to get the pads on. Now I have a soft pedal and was told I needed to adjust the piston back out a little bit but I cant figure how...
soft pedal usually indicates air in the system. when you put it all back together and applied the brakes did you check to see if the brake fluid in the master cylinder was topped up with brake fluid ?. it would appear that the system needs to be bled. check for leaks as well and it is possible you may have damaged the pistons in the calipers when you pushed them in to make room for the pads.
Nov 03, 2010 | 2008 Chrysler Town & Country
Mouse cursor moves by itself
two reasons : 1> your mouse is extra sensitive, go to control pannels and then mouse and lessen the speen of ur pointer. 2> you're using some cloth or some soft area as ur mouse pad, such things slip easily, try using a proper MOUSE PAD
Feb 08, 2010 | Dell Optical USB Mouse opmse-5
Why does my arrow keep jumping around on me, when I go to click on a particular area?
this happens when either you have faulty touch pad drivers or the touch pad is becoming faulty
try using a USB mouse to see if it also makes the cursor jump at particular areas
Sep 29, 2009 | Computers & Internet
The mouse pad on my new acer travelmate 4730 doesnt work
Hold down the function key (Fn) then press the F7 key. This is keyboard shortcut to toggle on and off the touchpad.
Sep 04, 2009 | MSI M510C Notebook
THE DISK THAT CAME WITH MY PANTECH DUO IS NOT COMPATIBLE WITH WINDOWS VISTA AND I CAN NOT SET UP MY PHONE
try this:
make sure Modem Link on the phone is set to Inactive by going to:
At the Home screen, press the left soft key to go into the Start menu.
  • Click on Settings.
  • Click on Connections.
  • Click on Modem Link.
  • If it is set to Active, press the control pad left or right to select Inactive, and press the left soft key Done.
However, if the Modem Link is was already set to inactive. Do the following:
  • At the Home screen, press the left soft key to go into the Start menu.
  • Click on USB to PC.
  • Make sure Enable advanced network functionality is not checked. Then press the left soft key, Done.
After performing this step the phone should connect to your computer via usb and Vista should successfully detected it and you should be able to copy files over and get it set up.
Dec 13, 2008 | Pantech Duo Smartphone
StreetPilot c340 will not power on - even with soft reset
well after being on hold with garmin for 32 minutes they told me to send them the unit back and will repair at no cost.
My unit was purchased on may 27th 2007.
Jul 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Master reset without using soft keys?
there is no code to make a fact reset on SE fones. But if you have the usb cable you can do it with some free softs.
May 20, 2008 | Sony Ericsson K800i Cellular Phone
Azend Group RH-200-3 - A4tech Rh-200-1 Wl Rechargeable Logo
23 people viewed this question
Top Azend Group Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an Azend Group Lock and Locksmithing Expert? Answer questions, earn points and help others
