Question about Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder
What type of cable to connect the camera to tv
    Top Expert:
  • Panasonic Master
  • 10,875 Answers
I connected it correctly and got no pic on my tv, the red light was on the cam, why dont i get a picture on my tv?
I would need more information on both TV and camera model numbers to determine if they are compatible with each other, AV should be the one but it would depend on the format of video like PAL or NSTC for example.
The cameras I have seen on Amazon are NTSC (US) type so if your TV is PAL type (UK) then they will not get along and its video signal will be of no interest to it.
Mar 30, 2017 | Wisecom Night Vision Camera w/ 100 ft...
No sound when trying to play back on TV. Can hear sound thru camera but that's it. It's a JVC GZ-HD320
Normally you require a cable to connect to the TV. It should have at least 3 RCA connections to connect to the TV: Yellow for video, red for right audio and white for left audio. The camera connector will have a small stereo type plug that has 3 sections on one stem corresponding to the yellow, red and white cables.
May 13, 2011 | JVC Everio GZ-HD320 Hard Drive Camcorder
I cannot show pictures on my tv from my sony 120 . I have the cords and the input on the tv but nothing happens when I try to show them???The manual suggest to delete the usb port???
You can either use the supplied A/V and USB Multi connector cable for connecting the Camera to the TV. Connect the Yellow cable to the Yellow port on the TV for Video and the Red and White for audio. Then select the proper input on the TV where the cable is connected.
You may also connect the HD Out of the Camera to the HDMI Input on the TV using the compatible HDMI cable for the Camera.
Before connecting the Camera to the TV, you may have to change the settings in the Camera depends on the TV type.
1. Component Settings from the Main Settings 2 Menu of the Camera should be set to HD or SD depends on the connection. Also depends on HDMI (HD) or A/V (SD) video connection.
2. Video Out Settings from the Main Settings 2 menu of the Camera should be set to NTSC or PAL depends upon the color system of the TV.
Try changing the settings in the Camera and connect it to the TV to view the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
IS IT POSSIBLE TO PURCHASE A CABLE TO CONNECT OUR SAMSUNG SL502 CAMERA TO OUR TV TO SHOW THE PICTURES ON THE TV SCREEN ?
After researching your camera model i do not see a output connection. Usually there is a output connection that will allow images to be displayed on another device such as devices containing rca or usb type connections for inputs.
Nov 18, 2010 | Cameras
Where can i get the right cable to put my recorded vidio on to my tv to whatch?
It will depend on the Make and Model of your TV set.
If you are using an Analogue TV or a Video Player/Recorder, it will have Line IN and AV IN connections (these are Yellow (Vision), Red (Audio) and White (Audio).
You can download the Manual for your camera from link below :
http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=VP-W60
Page 14 lists the components that came with and are available for the Camcorder.
Page 50 contains the instructions for connecting the Camera to the TV or Video via the cable that came with the camera or a purchased SCART cable.
Page 60 contains the Specifications for the Camera and the cable type is listed under Connections section (Video Out and Audio Out).
NOTE: Not all digital TV's have the RCA connections. However, some do.
I hope this is helpful. Regards,
Feb 10, 2010 | Samsung VP-W60 Camcorder
VP-D351 need to connect with TV. What type of cable is required
Make sure your TV is a PAL unit. The easiest place would be to look in the owners manual. If you no longer have it, there should be a PDF format online. It should tell you what cable you need.
Dec 18, 2008 | Samsung Compact MiniDV Digital Camcorder
What type of cable do i need to connect to tv
I believe all you need is a pair of "phono" leads the same as you find on stereo systems. One connects the audio (mono) & the other composite video (usually yellow connector). Your TV needs to have composite video connector. If not you can get an adapter for a SCART / PERITEL input the same as supplied with popular game consoles like xbox.
Jul 26, 2007 | Sony Handycam CCD-TR748 Camcorder
What cable do i need to connect to tv
Any of the following 3 will work. S-Video ? Composite (Video) ? Audio (RCA) Information taken from: http://www4.shopping.com/xPF-Sony-CCD-TR748 images of S-Video cable and Composite/RCA cables listed below.
And I have a project due tomorrow!!!
I would suspect either the cable connecting the camera and TV or the TV itself. What type of TV are you plugging into and what type of inputs are you connecting to?
Feb 08, 2007 | Sony DSC-T7 Digital Camera
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Logo
89 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
