Question about Korg Pa50 Professional Arranger Keyboard with SD Card Slot
Joystick does not work
Joystick doesn't change note sound
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
The PB sensitivity may be turned off for all the track(upp1,upp2,upp3,lowr).Turn this on to desired level.Also check the joystick settings.Turn that also on.PB sen and joystick options are there in menu.
Posted on Jan 02, 2015
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Apr 06, 2012 | Music
Nashville tele that has the g string sounds off when playing
if you have the adjustable bridge try moving it back a little bit. the g string is a heavy string and will tend to go sharp when you have the string height up a little. make small adjustments usually only one turn or half a turn at a time. take care to note your adjustments so you can always go back to where you started. turners are nice but the ear doesn't lie. if it sounds right it's right
Jan 19, 2012 | Fender American Deluxe Telecaster
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
Dec 06, 2011 | Casio PX-830 BK Privia
The pitch bend of my Korg pa500 Ort just stopped operating properly yesterday, the problem is that "up & down" is functioning normally but "left & right" is not working (no...
The first thing is to verify that it is supposed to work with a particular performance. NOT ALL voices support modulation as well as pitch bend and with an arranger you can turn this feature on and off, usually in the utility functions and then save the setting for each performance/song. Read you user manual about modulation. On page 271 of your manual they show that the joystick is assignable. You have to assign the functions to the effect you want.
Jul 30, 2011 | Korg PA500 61KEy PROFESSIONAL ARRANGER...
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
Our Yamaha YDP223 has an issue with the damper pedal. When it is depressed, the notes (F#, G) in the upper ranges make a high pitched, annoying sound as the note dies away. We were dealing with this sound...
All sound is generated digitally and the pedal doesn't modify the sound, it just sustains the generator. This is a strange problem and best suggestion iis to find another unit and compare... it may be a characteristic of the design. There isn't anything that you can do to change this. It could be there is a bad ground inside the unit or the digital data is corrupt in the processor. The fact that it is on a particular set of notes is strange...I just checked on my Yamaha piano that is essentially the same electronics and I notice that on one octave above the middle when one strikes F# and G they "ring out". Now this MIGHT be due to the characteristics of the speakers. Those particular notes seem to clash more. I don't have other speakers on mine and unfortunately you did not mention what brand model you have attached. Consumer grade speakers like fancy stereo speakers do NOT do well on these instruments. One has touse pro grade speakers AND use proper interconnecting cables. The speakers, powered type, must be powered from the SAME receptacle as the piano to avoid ground loops.
Feb 20, 2011 | Yamaha YDP223 Digital Piano
No sound from my EWI4000s but display of my fingering 1 to 12 which I did not note when the instrument was o.k. When I adjust breath sensor I hear a sound which stops as soon as I press fingers for any...
Try restoring to factory settings first by turning it on while holding down the Level,Fx,Setupand Trans keys all at the same time. Your key delay function might be out of adjustment. You also have to remember to keep at least one of your thumbs on one of the earth plates. Refer to your owners manual. Start with the factory settings and compare each page of the manual to your instrument until you familiarize yourself completely with the manual. Play the instrument for a while with factory settings until you decide where you have to make changes. Work slowly with each adjustment and the manual until you get what you want. Some adjustments will affect others. Take careful note of what the manual says about temperature and humidity changes.
Jun 20, 2009 | Akai Ewi4000s Electronic Wind Instrument
Korg Pa50 Professional Arranger Keyboard with SD Card Slot Logo
46 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
