Question about Canon PowerShot A540 Digital Camera
Image not visible on screen; but able to take snaps
Image being focussed is not visible on the screen.  However, i am able to click snaps.  Please suggest solution
Thank You
  • Anonymous Nov 16, 2007
    blank lcd
    Guru:
  • 1,894 Answers
Press the "disp" button once or thrice.
if no display comes take it t service centre
Posted on Dec 21, 2007
  • dewan nafees ahmed Jan 21, 2008
    you are very rude... you dont deserve your probelm to be solved i think.. if you rate all experts like this inappropriate.. change the ratiing..
Hi, the view finder and lcd display on my Samsung SDC-103 gives a fuzzy black and white partial image only. This is all that comes out when I record - though I can playback fine. It's been like it for...
The CCD image sensor of the camera has failed. It is the component responsible for capturing the image the camera is focussed on, display it on the screen and capture it. If its malfunctioning you are bound to see problems like these. Getting the imagesensor replaced should resolve the problem
Jun 16, 2011 | Cameras
My screen on the camera is white how do i fix it?
Hi there its repairable. But your question not so clear. If the image come proper but the LCD screen is white then the problem occur in LCD screen. So just replaced the screen. But after click the snap if that's white or dark ( no image ) then your lens connection or lens only damaged. So please let me know the image is came or not. Both are repairable. Thanks & waiting for your feedback.
Apr 01, 2010 | Fuji FinePix A345 Digital Camera
My camera will not focus. I have a 50mm lens and 200mm and neither will focus
Which exact lenses are you trying to use? The N2000 (aka F301) is a manual focus camera so if you're trying to use autofocus lenses you have to focus them manually. Sorry if this seems an insulting suggestion, but you did state "my camera will not focus" and I've learned that on FixYa it's best not to assume any prior level of knowledge with regard to those who post questions.
The next thing to check is whether the viewfinder has an eyecup attached, if so slide it upwards to remove it as sometimes they have a corrective lens fitted if the previous user needed corrective optics. If your vision is fine (with glasses/contact lenses if necessary) then a corrective lens on the viewfinder may make things look blurry.
Other than that, the only other possible cause (other than a pair of broken lenses) is if the focussing screen has become dislodged downwards (or somehow fitted upside-down) then the viewfinder image will be unsharp. Officially the F301/N2000 had a fixed focussing screen but it could be replaced with one of three designed for the higher specified F501 (which does have autofocus), and if not seated correctly you'd get the focussing issue you describe.
You can test if the focussing screen is the problem in one of two ways:-
1. A visual inspection (you may need to get a more experienced photographer to take a look at it);
2. Set the lens to focus at infinity and at the widest possible aperture and take a photograph of a distant object (ignoring the blurred viewfinder). process the film and inspect the photo. If it's sharp then you have a focussing screen problem. If not, then it's a lens problem.
If the problem is a poorly fitted focussing screen then it may just need reseating or to be removed and refitted. It's vital to do this in a dust free environment and to avoid getting fingerprints on the screen. Some screens sit in a hinged frame which then clips into place when pushed up, others push into a pair of clips towards the top rear and then the front is held in place by a spring clip: it's been a long while since I worked on the F501 or F301 so I don't recall which system is used.
Courtesy of Norman Butkus' website, click here for a free Nikon N2000 user manual.
I hope that you've found my answer to be of use, if so please return the favour by rating my answer.
Feb 06, 2010 | Nikon N2000 35mm SLR Camera
My pictures are not visible clearly on screen. they represent a very old situation as like they are very old.......please help
If the image is very dim and/or the screen is very dark, then you most likely have a backlight problem. To determine the exact nature of the problem, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 17, 2009 | Acer Aspire 4730-4947 Notebook
Compaq software
HI FIRST YOU HAVE TO START ON A BASIC SETTING YOUR SCREEN DISPLAY SETTING. CLICK START, CLICK CONTROL PANEL, CLICK DISPLAY AND CLICK THE SETTING TAB. YOU CAN ADJUST BY SLIDING THE SETTING TO THE RIGHT OR TO THE LEFT. AND EACH TIME YOU ADJUST CLICK APPLY AND OK. AND IF THIS WILL NOT WORK FOR YOU IT MIGHT BE YOUR MEMORY CARD OR THE VIDEO CARD. IF THIS IS LAPTOP THERE IS ALSO SETTING RIGHT ON THE KEYBOARD TO MAKE BRIGHT AND DIM. HOPE THIS WILL SOLVE YOUR PROBLEM.
HH
Aug 16, 2009 | HP Compaq Presario F500 F700 and G6000...
Pentax k1000 ....lens will not focus...(one 50mm...other 70-210mm)...happened once before...brought to camera store and of course it focused...nothing wrong...took some pics and worked ok...now not...
Try this first.
Set your lens focus to infinity and focus your screen at a far away object (like a distant lampost). If it,s not in focus, then you have a misaligned mirror. Adjust your mirror so that a infinity setting, the split-screen image merge well to form a well focussed image. Hope that helps.
Aug 06, 2009 | Pentax K1000 35mm SLR Camera
My webcam works online with messengers, but when I open it to take a picture, the picture is there but when I click the snap image it is a white screen. I think I need update drivers for vista because it...
Hi There,
I need to know the make / model number of your webcam before I can help you.
Please let me have them as soon as you can.
Thank you.
Philip
Nov 30, 2008 | Philips SPC 200NC Webcam
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Nov 12, 2007 | Canon PowerShot S500 IXUS 500 Digital...
JVC GR-D50E Digital video camera - on LCD view image is not displaying
if you live in very cold region, the mist or moisture give you this problem, using a hair dryer will solve this problem.
Aug 20, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Canon PowerShot A540 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
