Question about Sony Playstation 3 (PS3) Console
Hard drive disk is corruptted and i already tryied to restart it only will do 11% before it kicks out of system
  • 1,472 Answers
George_rdean
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Oct 09, 2010
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Hard disk cyclic redundancy check
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
Mac won't boot up. it spins and spins but never finished booting. it started after the mac accidentally lost power after a startup, before it was done booting. how can i bypass this and get to...
Two possible things are wrong either your hard drive has gone or your system has corrupted.
If your system is corrupted put your instal disk in start it up holding down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay so run the disk utility check drive and then run the repair permissions. Then try restarting, if it works then you are back up and running again. If the drive shows up and you restart and the same thing shows up, you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents your will need to use the preserve users instal.
If your hard drive does not show up the hard drive is probably a gonner and you will have to purchase a new hard drive and then instal a fresh system.
Hope this helps
Sep 06, 2010 | Apple MacBook Pro Notebook
I just received the system and recovery dics from Acer. When I insert the system disc, it loads and then times out with "please wait a moment..:
Then you may have a faulty hard drive, you didn't say why you had to get them, what happened? If your drive is OK? Then perhaps you need to format it first, with say UBCD, here download and burn to CD, and it has tools that will allow you to format and partition. www.ultimatebootcd.com/
Official instructions below.
Turn on you computer, if not already done. Place the Recovery Disk into your CD Drive. Restart the computer with the disk in the drive.
While the computer loads, you will be prompted to "Press any key to boot from disk." Press a key quickly as you are only given a few seconds to do so.
Follow the instructions on the screens to format your hard drive. When prompted to format the partition on your drive or to alter the partitions, select "Format" with the arrow and enter keys. Selecting "Alter" will not recover your computer.
Once the format is complete, you will be prompted to restart your computer. Accept, and while it boots again you will be prompted to "Boot from Disk," as in Step 2. Do not press any buttons this time as you have completed the formatting process already.
Windows will be reinstalled once formatting is complete. Remove the Recovery CD from the disk drive. Replace with the Driver Installation CD. Reinstall all your computers drivers with this CD.
  • If you accidentally select the "Alter" option in Step 3, restart your computer using the button beneath the Power button on your computer and follow Step 2 again. Store any files you want to keep on an external media, such as a CD or external hard drive.
  • You will lose all saved information on your hard drive, since using the Recovery CD will set your computer back to the factory default. Do not unplug or turn your computer off while the formatting or installation is in progress. Doing so may corrupt your hard drive and might render it unusable.
Feb 27, 2010 | Acer Aspire 5100-3357 Notebook
Hard drive file system corrupt
have to do to format the disk because it seems you have a virus or repair if you do not get new
Aug 20, 2009 | Sony Playstation 3 (PS3) Console
Question about the hard disk
Your hard drive has been corrupted. There is an easy fix that will not void any waranties (If you have them). Just buy a new hard drive (Mine is a 500 GB Samsung for $125). Then lookup instructions on how to replace it on the Sony website. It is a very simple process.
Hope this solved the problem,
Mike P
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have...
you already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Dec 21, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
