Question about Traeger Industries Grilling
My traeger smokes but won't heat up...I have it on high...not smoke.
My traeger smokes but won't heat up...I have it set on high.
    Novelist:
    Scholar:
  • 197 Answers
Have you cleaned the ash out of the firepot? I clean mine with a shop vac after every five or six uses because the ash builds up and "insulates" the fire, keeping air from the fan reaching it so it just smolders and never really gets hot.
Posted on Dec 04, 2014
  • 332 Answers
SOURCE: I have a Traeger Executive 100 with a digital
Call Traeger direct.
You have a bad control unit
Mike Treager is really good about replacing anything that goes wrong
Posted on Mar 07, 2010
gcken
  • 140 Answers
SOURCE: Our traeger smoker is smoking but is not emitting
You need to replace the element inside the smoker!
Posted on Apr 04, 2010
  • 18 Answers
SOURCE: My Traeger heats up but is not smoking. What's
What type of wood are using. I use mesquite - Oak - mapel - hickory Charcoal For the fire not all at the same time. After the fire is going need to buy Oak or Hickory or Mesquite wood large chips soak them in water for about 30 minutes. throw some into the fire about every 20 30 min.
Posted on Feb 20, 2011
  • 4736 Answers
SOURCE: should my traeger be 350 smoke and med it over
Your question was rather confusing, but the generic answer for smoking any type of meat. poultry or fish, is 225 - 250 degrees F. Any hotter, you've gone from smoking to grilling. Smoking any type of food is "a low & slow process."
The adjustment for maintaining a certain temperature with a smoker is by opening or closing the air intake damper(s) Closing the damper(s) slows the intake air flow to the fuel and it burns slower and cooler. Opening the dampers does the opposite.
Hope this helped you. Please let me know.
Posted on Jun 15, 2011
  • 2550 Answers
SOURCE: The barbecue smokes considerably.
It could be it just needs a clean bottom tray under burners could need cleaning
Posted on Aug 28, 2011
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Jun 14, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Our traeger smokes but the fan does not run consistantly?
The fan is not supposed to run consistently. The purpose of the fan is to help control the temperature. It runs hard at first to help get the fire started then it slows down to maintain the temperature you've set. If you change to a higher temperature or if the temperature drops below what you've set, the fan will run faster causing the fire to burn hotter. You'll also find that as the temperature increases the amount of smoke will decrease.
May 06, 2014 | Traeger Industries Grilling
Traeger grill get to hot on smoke
If you're cooking when it's hot outside, it's hard to maintain low temperatures. In the heat of summer, I have to tend my grill continually opening and closing the lid to keep the temperature down to my cooking temp of 180. That, of course, lets the smoke escape. If it gets too hot when the temperatures are moderate, i.e. 60s and 70s, the augur may be dumping too many pellets into the fire pot and need realigning. I suggest you contact Traeger customer service at http://www.traegergrills.com and see what they suggest.
Apr 20, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Not smoking
Traeger grills just will NOT smoke at temps much above 200 degrees. I have to stand by my grill continually in the summer to keep opening and closing the lid to let the heat out. That also lets the smoke out. I also have turned the grill off and on to try to maintain the temperature at 180 degrees where it smokes best and cooks low and slow. It's less of a problem in the winter months. Then I find myself setting the temperature higher turning it from low to medium and back to maintain the temperature I want.
Mar 30, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Im getting black smoke --like creasote in my Lil Tex--What causes that?
If there is a small amount of black smoke, a little amount of carbon, don't fuss. It's normal. Remember low heat means a lot of smoke, high means quicker cook time, less smoke.
Jul 23, 2010 | Traeger Industries BBQ100 All-in-One Grill...
On several occasions,in smoke mode, after several
the smoker does not emit smoke continuously. The pellets are pushed into the firepot at a speed relative to the temp setting. If you listen to it you will hear it go through the heating cycle and see that is a normal condition.
Jul 07, 2009 | Traeger Industries BBQ070 All-in-One Grill...
Grilling Logo
323 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
