Question about Caruso Molecular Steam Hairsetter 30 Rollers C97953
No steam coming from unit - Caruso Molecular Steam Hairsetter 30 Rollers C97953
Turn on steam in shower, but no steam comes out
So many things could be wrong. 1 check circuit breaker. 2. Check there is water going to steam unit. Power to control in shower? Steam unit could be burned out. Or control is not working or thermostat not working.
Apr 08, 2015 | Electrical Supplies
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
Electrolux z380 steam cleaner issue
Try this:
1. empty the cleaner.
2. pour some vinegar after DISCONNECTING POWER. Shake the unit for a few minutes and now empty the cleaner and watch what comes out as you shake out vinegar.
3. pour water into the unit upto suggested level and power up after closing the top lid securely.
4. wait until the indicator light turns off (if you have one).
5. press button to see if steam comes out.
warning: Never open the top cap while the unit is powered. you may get burnt badly.
good luck
Jan 26, 2014 | Kitchen Ranges
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
My steam mop will not steam. the light comes on and it seems to heat up, but no steam comes out
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I do not have steam coming out of the mop i have it plugged in
i would take it back,IF YOU R FILLING IT WITH WATER AND ITS NOT PRODUCING STEAM,ITS BROKEN
Jan 27, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
Oct 03, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Shark steam mop
heatman101
ab
May 29, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Jan 03, 2008 | Euro-Pro Steam Generator EP8001 Iron
Caruso Molecular Steam Hairsetter 30 Rollers C97953 Logo
173 people viewed this question
Top Caruso Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Caruso Health and Beauty Expert? Answer questions, earn points and help others
