Question about Standard Motor Products 1981 - 1984 Dodge D250 Ballast Resistor RU-37
Wont start hot ballast
Car died motor will run if I crank with the gas to the floor -- but won't idle.. I have gas to the carb
JUST REPLACED CARB ON MY 1992 CHEVY SILVERADO WITH A 4.3 LITER. NOW IT STARTS AND RUNS FINE UNTIL IT WARMS UP THEN DIES AND WONT START FOR 30 MIN
How many rpm's is it running at when you first start it up and it is running on the choke? Does it gradually start to idle back and then start to die r does it do it all of a sudden and dies?
When running with the choke on, it is on the high idle circuit of the carb, as it warms up the idle should slow down and then idle in the 800 rpm range in Park, 650 in Drive. This will be the low idle circuit range. This transition inside the carb will cover an idle air bleed hole in the venturi of the carb and lean out the mixture. If you notice that the carb smells gassy and black rich unburnt gases are coming from the tailpipe, the problem is located within the carb and requires a carb tech to do a rebuild of the carb. You could try a good carb cleaner like Lucas by putting it into the gas tank, in case you just got a bad tank of gas, but that is just a bandaid for a more deeply rooted problem. Get the carb rebuilt?
Nov 27, 2013 | Cars & Trucks
85 vette starts runs a few seconds dies. could it be a crank shaft sencer
if you need to keep your foot on the gas to keep it running clean the throttle body and idle speed motor
Aug 20, 2012 | 1984 Chevrolet Corvette
I have 1999Chevy suburban with 6.5 turbo diesel motor.it idles up and down and when driving the gas pedal is real touchy Wat is the problem and were do i locate the problem
Check the help links related to this problem.Click the link below to go through its troubleshooting procedure :-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html---------
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
-------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down?
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
After replacing brake rotors and pads, brake pedal remains on floor? http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
accelerator pedal sensor? http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
For rough idle issues and problem troubleshooting,go through the help links provided below :----- van idles rough?
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
This will help.
Thanks.
Mar 01, 2012 | 1999 GMC Suburban
Car starts after taking foot off gas car shuts down 2001 mit 3.0 v-6 spider
For this problem, i suggest you to go through this help links.Click the link below to go through the troubleshooting procedure :----Car Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html
-----------Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
---------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
------------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down? http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
-----------This will help.Thanks.
Feb 15, 2012 | 2001 Mitsubishi Eclipse Spyder
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
I have a 1985 Dodge slant 6 225 ci. When I try to start the motor the only way isto shoot starting fluid into the carb. Once the motor is running it wont idle and when I try to pull out it starts out ok...
sounds like you have a major carb problem i would rebuild it or buy one from the parts store already rebuilt ..dont forget a new fuel filter!.....also check your fuel pump for pressure and volume.
Sep 19, 2009 | 1985 Dodge Pickup 4WD
Took out to the lake runs fine for awile but once you let of the gas and it dies wont crank back up put carb cleaner and they ran fine now wont crank up aqain
Carb needs rebuild...idle jets clogged. That is why it will rum at high speed...the high speed jet is bigger and harder to clog. The idle jet is small and easy to clog. take apart and clean up jets.
Jul 18, 2009 | Boating
1989 virago wont get rpms up after start
is it just out of winter storeage? could be gum in the carbs, get some fuel system cleaner additive and put it in the gas. run it on idle and get it hot, leave to stand overnight and try again. you are not getting enough gas and when you open it up you are giving more air but not getting enough gas. try changing fuel filter too.
Apr 01, 2009 | Yamaha V Star 1100 Classic Motorcycles
Standard Motor Products 1981 - 1984 Dodge D250 Ballast Resistor RU-37 Logo
77 people viewed this question
Top Standard Motor Products Electronics - Others Experts
Are you a Standard Motor Products Electronics - Other Expert? Answer questions, earn points and help others
