Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konica cpp 500 how to fix the temperature - Konica Minolta bizhub C250 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
Sir/Mam, turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Posted on Jan 13, 2016
Konica minolta bizhub 500 has malfunction : c-3902. i tried powering off and unplugging...no help... now what?
This is a fusing unit problem. Specifically TH@ also known as Thermister 2 is not detecting tempurature the same as TH1. Here is the quote directly from the service manual:
Inferior contact of the thermistor
/2 (TH2)
While in the warm-up condition,
when the thermistor /1 (TH1)
detection temperature gets to the
Ready temperature before the
TH2 detection temperature, the
TH2 detection temperature does
not get to the Ready temperature
a specified period of time after
the TH1 detection temperature
got to the Ready temperature.
Basically what you are going to need is a service tech to come out and replace TH2.
Good Luck and Thank You for using Fixya.
Aug 31, 2010 | Office Equipment & Supplies
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
Sir i write a cd i get this error somu 4C85-1000-0805-6481-407K-8KE9-**** Windows XP 6.0 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 (Nero Express) Recorder: ...
turn off buffer underrun protect in neros settings. It gives back the wrong info to nero causing it to crash. Contact nero about the issue. there may be a patch on the nero site to fix it.
Aug 30, 2009 | Acer Aspire 4720 Notebook
Sharp Actius AL27 strange DVD burning problem - The drive will burn a DVD+RW at 4x. A cheap (Imation) DVD+R burns OK, but a good 16X DVD+R (Verbatim) tries to burn at 2x and fails a few minutes in. This...
man it's not a condition that if the DVD Bulck writeen on it 16X that ur DVD writer will burn on this speed.
always don't try to burn ur DVD on maximum, always use the previous speed or the last previous one
ok good luck
Jun 17, 2009 | Sharp Actius AL27 Notebook
F35 error code
Warm-up was not completed
within a specified period from
the start of warm-up.
• The low fixing temperature
fault detection software is
activated.
The fixing temperature at the
end of warm-up is less than the
specified temperature.
activated.
The fixing lamp does not turn
OFF within the specified period.
SOLUTION
Rewrite the data at
address “P47” in the
25 mode to “0”.
(1) Turn the main switch OFF.
(2) While pressing the numerical keys 2 and 5 of the copy
quantity setting button, turn the main switch ON. This
will enable the 25 Mode. The 25 Mode is used exclusively
to rewrite in memory and, therefore, does not
support normal copy operations.
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Memorex DVD+R DL 8.5 GO 8X compatibility
If all you are looking to do is write a DVD (ie, burn ordinary OS-managed files onto DVD, without transcoding, etc.), or write transcoded DVD-structured files, or an .iso image file, then don't even try to use Nero. Use ImgBurn, it is 500% better for those kinds of tasks, and it's freeware. I use it to burn DVDs but use Nero to transcode files and create the VIDEO_TS folder files. I then use ImgBurn to convert them to an .iso file, then burn it to DVD, also using ImgBurn. URL: http://www.imgburn.com/
Mar 30, 2008 | Ahead Software Ahead Nero 6.3 Suite 1...
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
