Question about Directed Electronics Vehicle Parts & Accessories
Kia carens wiring diagram
Alarm
4 Suggested Answers
Magaiver
  • 707 Answers
SOURCE: how to fit a wheel bearing to a kia carens front
It is only a four bolt sistem to change after the brake *** is removed. U may also have to remove the upper and lower control arms.
Posted on Aug 10, 2010
  • 4793 Answers
SOURCE: kia carens 2003. (UK) Don't know alternate name.
take out all the screws in the door handles etc,slide the chrome suround forwards on the interior doorpull and remove.then, very carefully prise off the inner door panel(use a Y tool for the clips,or a wide screwdiver..you will break some) with the window up,you will be able to see a wire hanging down from the outside handle,it is the clip that holds this on that is broken(very common)if the clip is okay then you will have to see what else is needed.but it will be obvious.
Posted on Aug 13, 2010
ercupa190
  • 12223 Answers
SOURCE: Kia Carens overheating
see this causes and remedies, you can have overheating by internal leak or external leak:
1) transmission oil cooler is leaking , 2) loose cylinder head gasket 3) engine block cracke 4) cracked cylinder head or engine block bore 50 oirl cooler is (inside radiator) is cracker.
2) external: a) leak at the hose connection b) water pump c) core plugsd) thermostat housing e) cilynder head.f) gasket cylinder head.
God bless you
Posted on Jul 18, 2012
How do I flatten the back seat of my KIA Carens 2003 model to make more luggage room space?
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, codes, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
Feb 26, 2018 | Kia Cars & Trucks
Kia carens problems
look in the runner for a dropped coin!
Dec 08, 2013 | 2009 Kia Carens 2.0
At times the hand brake light comes on when the kia carens is in motion what are the causes
faulty brake light switch on the handbrake change it will be fine you will find this near the handbrake lever there will be 2 wires going to it
Nov 29, 2013 | Brodit ProClip for Kia Carens II 2003 -...
The horn of my KIA CArens has stopped working. I suspect something at the push at the steeing wheel. Any help
check horn fuse
measure voltage at horn
one wire will be earthed to car body hopefully and the other wire will get plus 12 volts when the horn is pressed.
or one wire is always 12 volts and the other wire is connected to earth when horn button pressed.
check fire wall of car some kia have horn on firewall in engine compartment. or it is under the grill in front of car.
Sep 07, 2012 | 2005 Kia Carens
I have a kia carens 2001, making a knocking on right side when accelerating and turning left and a lil on the right and steering is jumping when accelerating and at 70km pls help
common fault on kia carens is the drive shafts ive had to replace both mine its a easy job to do but will set you back about 130 pound a side.
Jun 04, 2012 | 2005 Kia Carens
How to fite reare pads to kia carens
you need c clamp to for,s back piston on caliper
Feb 15, 2012 | 2005 Kia Carens 2.0
Kia carens 2003. (UK) Don't know alternate name.
Aug 13, 2010 | 2005 Kia Rondo
How to fit a wheel bearing to a kia carens front wheel.kia carens is not in the drop dowm menu
Aug 10, 2010 | 2002 Kia Sedona
How do I get to the heater filter on my 2009 kia carens . I am presuming the pollen filter is behind the glove box, but I cant see any screws to get the glove box assembly out or in fact where the filter...
I eventually found the answer to my problem on a website called kia-forums.com telling me to open the glove box and pull it sharply and backwards.it disconnects from the plastic hinges. The filters are easy to replace by unclipping the cover which is easy to see. This is for a 2004 kia carens
Dec 30, 2009 | 2007 Kia Sedona LX Minivan
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
