Question about Western Digital Computers & Internet
Error 1002 what is error 1002? Im tired of trying to solve problems Smith my wd cloud
How to fix wd passport fatal error
Stick a fork in it its done, if you need the info off of it there are companies that do recovery but it's expensive. That is why you back things up or possibly on the cloud , Good luck and it's happened a lot of us so don't feel bad
Feb 18, 2015 | Western Digital WD My Passport Essential...
Why can I not connect a MacBook Air with a WD MyCloud using a Nexxtech USB 2.0 Data Link Cable ?
The USB port of the My Cloud is designed to be used as an extension port. You may use it to attach another external to the My Cloud or device like a camera. If you prefer cable connection between your PC and your My Cloud, I would recommend you to use an Ethernet cable.
http://community.wd.com/t5/WD-My-Cloud/Connecting-My-Cloud-to-MacBook-Pro-directly-with-Ethernet/td-p/717882 - Check this similar topic in the official WD community.
Hope this helps
Sep 07, 2014 | Computers & Internet
Error code:103-1002
Here's the solution to solve the problem.
1. Check your internet IP address. If the Wii-U is having trouble connecting try entering the IP address manually and the DNS manually.
2. Check the password to see if you entered it correctly. You may be using a T1 trunk Lindsey to security.
3.Finally check for outside interference, such as microwaves, smartphones, or other devices. If this still dosen't help, call Nintendo at 1800-255-3700 for assistance. Hope this helps.
May 31, 2014 | Nintendo Wii U
When i restore my iphone it stops at the end and says problem 1002
Okay so error 1002 is a baseband error. Either your baseband software is bad and you need to flash to the newest version, or the baseband hardware is shot. If your hardware is shot, guess you need a new logic board etc. But as I just researched some more on that issue I did find that Sn0wbreeze 2.5.1 will bring a fix to iTunes "error 1002 & 37 which was mainly experienced by iPhone 3GS users while restoring iOS 4.3.1 custom IPSW coupled with iPad baseband 06.15.00." Anyhow, might be worth a try, not much to loose I suppose. If you are looking to download it or to get more info, it is here. Good Luck to everyone.
Jan 07, 2012 | Apple iPhone 3G
MY HP DV5 1002 AU HEATS VERY MUCH.PLZZZZ HELP ME HOW CAN I REDUCE THE HEAT???
If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 28, 2010 | HP Pavilion dv5-1002us Laptop PC
Hp error code for compaq presario code 1002
http://h30434.www3.hp.com/t5/Operating-systems-and-software/Recovery-Error-Code-1002/m-p/11366
Jan 21, 2010 | Computers & Internet
Error 0x400 100 130000 1002 - hp pavilion 2700
I am using hp System Recovery Discs on a dv6000 series entertainment notebook and I just got an error: Error 0x400 100 130000 1002
If this issue continues, please contact HP support
My pc is out of warranty and HP wants me to send it in and they will fix it for $398. I will not do that. does anyone know how to fix this?
Jul 11, 2009 | Computers & Internet
Death wobble
Check your track bar (panhard bar as some call it). It goes from the driver side frame to the passenger side axle (not from the steering box, but close to it). Have engine running, and turn steering wheel back and forth. If driver side of bar (frame side) moves up and down while steering wheel changes direction of rotation, replace it. Good luck.
Jul 09, 2009 | 2004 Jeep Wrangler
Blue clouds in the screen of a Mitsubishi WD-62527
i have had similar problems before for me it was caused by a strong magnet on the floor below me. i suggest looking around for a strong magnet that could cause the problem
Jun 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
How to replace Bad Capacitors on a Mitsubishi WD-62525?
#1 press menu on mitsubishi remote control.If the white round cloud don't go.
you need to replaced block optical......light engine
Sep 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Computers & Internet Logo
181 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
