Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Replacing electrical cord
I am trying to fix/replace the electrical cord on this vacuum and I read somewhere to take the long screw out and the handle will come off. I did that and have pryed on the case a little (no damage) and to no avail. Does anyone have any ideas or maybe someone out there has done this before. Thanks Richard
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: I need to replace vacuum hose
If you have a vise, put the end in to and you want to just squeeze it so you can get to the 2 tabs inside and using 2 flat blade screwdrivers, pry outward and the hose should come out of the cuff. Sometimes you can just cut and rewire, but watch and match colored wires to the right colors, mix them up and you would have a electrical mess. When you put it back together, push the cuff down until you hear it snap into place.
Posted on Mar 25, 2008
Benimur
  • 6966 Answers
SOURCE: my 8 yr old kenmore
Have you tried spraying the stubborn screw with WD40 and let it soaked for a while? Other than these screws holding the handle together, there would no other way of opening it up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
  • 97 Answers
SOURCE: Replacing the electical cord on Kenmore Progressive Vacuum
To the right of where the cord comes out of the machine is a large screw. Remove it, and slide the upper handle assembly free.
Then, on the front of the machine, remove the screws located toward the top of the vacuum just inside the bag chamber cover. This will allow the front panel to be removed, giving you access to the cord from the front.
-R
Posted on Sep 15, 2008
  • 97 Answers
SOURCE: Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Posted on Mar 03, 2009
How to replace cable cord
You will need to remove the screws where the cable enters the rear of the vacuum . You will notice the cable is retained with a small plastic clip , remove this clip, unscrew the cable cut out the damaged section and reconnect. Ensure retaining clip is replaced. Now put the screws back into the machine body,
Apr 26, 2014 | Miele S7210 Bagged Upright Vacuum
It started to spark at the cbale in the handle - seems to be a fixed unit, can it be fixed? hoover still works great, woeld be waste to have buy new one, thanks
You can remove the entire handle and cable by unlocking the handle at the bottom above the main dust bin. There should be a lock with an arrow on it, like a rectangle which you pull upwards - this will unlock the handle with the cable. Or there may be a twist lock dependent on the vacuum you have. Replacement handles with cords are available to buy online but if you are good at wire/electrical wire replacement, you can follow online videos on how to replace the original power cord.
Sep 06, 2013 | Sebo Vacuums
Lately, my Kirby Ultimate G has been acting funny. When I push it forward, it's fine, but when I pull it backward on the carpet, the light on the front flickers and the power flutters off an on. I...
The cord will need to be replaced with a cord made for the machine, as it has a non-standard plug. The cord cover is held in place with a # 20 Torx screw. Remove the screw and push the cover gently from behind to unlatch it. The handle must also be removed, along with the switch "scuff" plate. To remove the rear plastic trim plate, remove the screw at the bottom rear, and the upper screw holding the cord to the motor shell. The upper screw is a # 15 Torx screw. To remove the trim piece, insert a flat screwdiver into the rectangular slot in it and pry it upward. Reverse this proceedure to install the new cord.
Feb 07, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Sebo has become erratic in electrical power and today I have sparking from the top of the electrical lead where the wire goes into the handle. Can this be fixed?
yes it can be fixed.
If you are handy or someone in the house is handy you may even be able to do this yourself.
All that is required is to remove the one screw out of the handle there near where the cord goes into the machine. Cut the cord off the unit about 2 inches from the handle.
Open up the handle and follow where the cord goes to, and disconnect the cord from the switch. Both the white and the black will go to the switch.
Feed the cut cord through the handle.
Bare off about 1 and 1/2 inches of the cord you just cut, bare off the black and white and replace onto the switch.
Reassemble everything and you should be ready to rock and roll again.
Good luck.
Mark
Nov 11, 2010 | Sebo X4 Bagged Upright Vacuum
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-s183-upright-parts-diagram.gif
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
GoVacuum
Apr 07, 2010 | Miele S183 Powerhouse Bagged Upright...
Sebo Automatic X1 Stopped. Yesterday my Sebo stopped working. I know this can happen if it gets blocked and overheated so I checked for blockages, none. And left it too cool down. Tried it again but it was...
Ok, thanks for the clarification. Even though the cord doesn't have any external damage, it's still very possible that it has gone bad. When a Sebo upright doesn't even start, this can mean one of several things. The parts that could go bad that would cause the machine not to turn on would be the cord (most common on a Sebo), the on/off switch, the PC board that's on top of the motor, or the actual motor. In the 7 years that I've been selling Sebo, I have only changed out one PC board, and I've never had to replace a single motor on a Sebo yet. I have had to replace several cords over the years, some showing external damage, others didn't show any damage.
The cord and the switch are going to be the easiest parts to test, and also happen to be the most common, so this is a great place to start.
Here's how you can test the switch and the cord on the vacuum cleaner. You'll need to have a simply Electrical tester that will test if current is going through the cord. Here's a link to a similar one that is very inexpensive that I used in this repair solution:
http://www.homedepot.com/h_d1/N-5yc1vZ1xh7/R-100183054/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Step 1. Unwrap the electrical cord from the vacuum cleaner, and set the entire cord aside. Also remove the on-board wand that rests directly behind the bag housing. After the wand has been taken out, you should see on the left side of the vacuum where the handle goes into the body of the vacuum a little gray lever (my picture this lever is yellow as I only had a Sebo X5 on the floor, but the repair is identical). This is what the lever looks like:
Step 2. As you'll see if you look closely, the lever says "closed". Turn the lever towards the front of the vacuum so the lever reads "open".
Step 3. Once the lever is moved to open, lift straight up on the entire handle assembly to remove it from the vacuum cleaner.
Step 4. Once you have the handle assembly out of the vacuum cleaner, turn the handle upside down. You'll be able to see two small metal electrical terminals that connect into the base of the vacuum where the handle meets the vacuum cleaner. Make sure that both terminals are visible. I have seen a few Sebo's where the handle has come loose, and these terminals no longer make connection to the rest of the vacuum, causing the vacuum not to turn on. You can re-attach the handle into the vacuum cleaner, turn the lever on the side from open back to closed, and test the vacuum to see if it comes on.
Step 5. If the vacuum failed to come on after reinstalling the handle, take the handle back out of the vacuum. Put one of the wires from your electrical tester into each terminal in the bottom of the handle assembly. Make sure that the tester is actually making contact with the metal terminals. It should look like this:
Step 6. With each of the electrical tester wires pushed down into the handle and making sure they are making contact, plug the cord into a standard wall outlet. If current is present, the electrical tester will light up. If not light comes on, try flipping the on/off switch and see if this has an effect on if the tester lights up or not:
As you can see in the picture above, the cord and switch on this vacuum are good. If your tester lights up when you put it into the handle, then this means that your cord and switch are good. This means that either your motor, or PC board have gone bad.
If the tester signals that you don't have any power at the bottom of the handle, then this means that either your switch or your cord is bad.
If you will please let me know the results of the electrical test here on the bottom of the handle, I will then go into the next steps of the repair, and explain how to open up the machine and either replace the cord / switch, or if you did have power here, the pc board or the motor.
Please just use the clarification request form that you used last time. I hope this was helpful in diagnosing your machine. If this helped you, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of the repair.
I look forward to helping you fix your Sebo.
Chris J.
GoVacuum
Apr 06, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Mrs Cleaner
hi
dsc04925t.jpg dsc04924t.jpg This should go without saying, but the first step is to unplug the machine. Next, open it up and remove the bag. Now you will need to remove the lid. There are white plastic clips on either side that you must carefully disengage by pushing them towards the center of the machine. Click the picture above and you can see that the right side clip has been disengaged. dsc04923t.jpg dsc04919t.jpg Once the clips are disengaged, the lid can be lifted clear of the body. Note the thin black plastic tabs on the lid that insert into slots in the body. Set the lid aside someplace safe where nobody will step on it. As an aside, I have twice replaced the dust channel, the fragile black piece of plastic visible at the top of the lid. Fortunately it is not a terribly expensive part and it is very easy to replace because it is only secured by four screws. Go back to the vacuum cleaner body. The next step is to remove the air filter. It is secured by two fairly obvious screws. These screws also hold down the switch assembly, which we will remove in the next step. But for now, go ahead and remove the screws and lift off the air filter. Put it aside where you won't lose it. dsc04915t.jpg dsc04907t.jpg Here you can see that the air filter has been removed and we are ready to remove the switch assembly. At this point the only thing holding the switch assembly to the body is the electrical connector underneath, and a plastic pin or two. Get a good grip on the switch assembly and lift it straight up with a firm but gentle tug. This is the underside of the switch assembly after it has been removed from the body. The white rectangular electrical connector in the center mates to the black rectangular electrical connector in the body, seen on the next picture. Put the switch assembly in a safe place until we reassemble the vacuum cleaner. dsc05469t.jpg dsc04910t.jpg Here we see the body with the switch assembly removed. We're almost there. The next step is to remove five screws, one of which at upper left is hidden in a deep recess. Click the picture above to see the location of these screws. The five screws have been removed. Carefully flip the vacuum cleaner over so that the black bottom and the wheels are pointing up. dsc04909t.jpg dsc04906t.jpg Here it is, belly up. Nothing is holding it together at this point, so just lift the entire base (the big black part) off and set it aside. It is not necessary to remove the rubber bumper that goes all the way around the outside of the base. As I learned the hard way, It is difficult to reattach. The inside of the base is likely to be pretty grungy. You could clean it up a bit with a damp cloth (I did), but there are wires in there so I wouldn't get it too wet. dsc04908t.jpg dsc04902t.jpg At last! The Miele's  innards are exposed. The motor is at the bottom of the picture and the cord winder is at the top. Remove one screw securing the cord winder electrical connector and then disconnect the electrical connector. You may now lift out the cord winder and replace it. I was also having an intermittent electrical connection problem which I thought was related to the problematic cord. It turned out to be an unrelated problem with one of the electrical connectors in the center of the machine, pictured above. Part of the plastic clip designed to hold the connectors together was cracked. Unfortunately I did not have a replacement part, so for now I wrapped some electrical tape around the connector to hold it securely together. This seems to have done the job. But the next time something else breaks on this Miele, I will order this part too and replace both at the same time. Follow the instructions in reverse to put your vacuum cleaner back together.I hope you found my little tutorial useful.
Dec 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
-R
Sep 15, 2008 | Kenmore 31913 Progressive Direct Drive...
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
29 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
