Question about Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator
It won't get cold
Power works but refrigerator won't get cold
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
My freezer works but my refrigerator won't get cold
There are a couple common things that could cause this problem here is guide that explains them:
Refrigerator Wont Get Cold But Freezer Will
Apr 10, 2013 | Whirlpool Refrigerators
Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Mar 26, 2013 | Refrigerators
Won't start
Make & model number would help. What do you mean NOT WORKING...not cooling, not operating, no cavity light...etc. Could be many issues, if there is cavity light then there is power to unit. Other items...compressor start device, cold control, defrost timer, rodent issues. Fan issues.
Mar 29, 2012 | Refrigerators
I have a domentic rm2652 rv refrigerator/freezer. the unit was working but now it won't work. The power light doesn't come on and it won't work on gas or electric.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Dometic RM2652 Refrigerator
Won,t freeze frig won,t get cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 18, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
The freezer will not freeze and the frigerator is getting warm. we had a power outage and now it won't work
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
May 11, 2011 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
