Question about Philips 55P8341 55" Rear Projection Television
I have a 55 inch phillips tv that is showing a red line and also a double figure. the red line is along the outline of persons, numbers, etc. etc.
  • Philips Master
  • 3,459 Answers
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directii have a 55 inch phillips tv that is showing a red - 0667c5f.pngnvergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 21, 2009
THE COLORS RED &GREEN ARE NOT LINE UP SHOWING DOUBLES
My Phillips 55 inch televison comes on but no picture or sounds and the on and off button flashes.
Aug 05, 2009 | RCA Televison & Video
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Double words
Sounds like your red is out of convergence. You may be able to adjust the convergence in the TVs menus. It may also be possible that the TVs convergence circuitry has gone bad. In that case it would be worth to have the TV repaired, convergence board are usually fairly inexpensive.
Oct 27, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Red outlines in the picture
somewhere in the tv menu there is a place to make video adjustments. one should be for aligning the color guns. one is for red and the other two are green and blue. it will give you a cross in the center of the screen. it should also give you prompts to adjust the lines for centering and to save changes. this happens eventually on all rear projection tv sets.
May 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Bad picture
The STK392-040 Is Convergence correction circuit! but the question is... what is the result when he replace the said parts? ok lets see... the probs. of your TV is a small parts like capacitor maybe this capacitor has change of value thats why the convergence is not in align...
Sep 14, 2007 | Samsung HCN5527W 55" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
181 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
