Question about New World E70DOa Electric Double Oven
Turned my e70doa off at mains and bottom oven will not work?
I turned my oven off at the mains and when i switched it back on the bottom oven doesnt work, also how do i change time again? thanks
4 Suggested Answers
SOURCE: New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to david.stevens@vibanalysis.co.uk and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Posted on May 04, 2008
  • 57 Answers
SOURCE: When I was using main
Sounds to me to me like a direct short. Hot wire in unit could be touching part of unit. Oven switch if it has one or main board could be shorted. Oven will have to be pulled to check. Slimm possibility weak breaker.
Posted on Mar 02, 2011
strife_cloud
  • 96 Answers
SOURCE: bottom oven no longer heats
Thank you for writing in regard to your oven.Let me help you with this. The best thing you need to do is to check if the heater or the heating bulb is in placed. If the bulb is in placed, then the next is you may need to chnge the bulb because the bulb is no longer working.
Posted on Jun 16, 2011
How do you get that black box open at the back of the oven so I can connect it please?
You need to use TWO small screwdivers, one each side, below the corners of the lower edge (see the mouded illustration of the box itself). You can then release the catches and genly lever the box open from the bottom.
Apr 26, 2012 | New World E70DOa Electric Double Oven
E70doa timer
You should be able to get the New World E70DOa from manualfox.com
- they have listed it on their site.
Nov 15, 2011 | New World E70DOa Electric Double Oven
Bottom oven no longer heats up on my E70DOa.
Jun 16, 2011 | New World E70DOa Electric Double Oven
Neff u1661n2gb/05. main oven not working and shorts out electric when try to switch on. top oven works no problem
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Nov 16, 2010 | Neff U1661 Double circotherm super...
Can not set clock
For the NW09DO, press the outer two buttons ("-" and "+") together and hold for three or four seconds. Then press "+" to advance the clock/time and "-" to go back.
When the correct time is showing, leave the buttons alone for four or five seconds.
Feb 19, 2009 | New World E70DOa Electric Double Oven
Dave
Apr 27, 2008 | New World E70DOa Electric Double Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
I DIDN'T GET AN INSTRUCTION MANUAL
I dont know if you've solved th eproblem of getting the gyrooven working but if you press down the button that looks like a pot cooking and press the + button to whatever timer you want the oven will then work. Mine does anyway!
Oct 29, 2006 | New World E70DOa Electric Double Oven
New World E70DOa Electric Double Oven Logo
32 people viewed this question
Top New World Ovens Experts
paulcarew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
