Question about Dell 924 All-in-One InkJet Printer
Paper jam i removed the paper pushed the start button as says but still says remove paperm jam will not work help please
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
Had the same problem with my Dell AIO 942. Found the solution at http://en.community.dell.com/forums/t/18044557.aspx?PageIndex=2
Posted on Jun 15, 2009
Paper Jam
Hi Matt,
Here's how to:-
  • First turn the printer off and on.This is known to automatically clear paper jams by pushing the stuck paper out.
  • Remove all the papers from the feed trays.
  • Remove the cover from the housing of the printer to gain access into the inside of the printer.
  • Check for the jammed paper inside and gently pull it out.
  • Press on the flashing paper jam button to make the clearing easy.
  • If this doesn't clear the jam,unplug the printer from power and try removing the stuck papers firmly.
  • Plug the printer back and try printing now.
Check out these video tutorials for more on the same.
Hope this helps.Thanks!
Dec 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Carriage jam on 926 dell printer
Here are some steps that can resolve your issue about paper jam.
Try to lift the paper exit tray, then remove the papers, then lower the paper tray and press the select button in the printer. If still the same, Raise the printer unit and check if there's a paper jam then try to remove it, close the printer unit and push the select button. If still the same try to open the access door in the back of the printer, remove the paper jammed, close it then push select button.
For more information about step by step procedure with visual click on the link.
Hope this will help your issue.
Thank you for choosing fixya
Mar 03, 2011 | Dell 962 Photo All-In-One InkJet Printer
Hi, My hp k550 is blinking at lights 1 and 4. How can I fix this problem please? Thanks
Issue
The power light and resume light is blinking.
Power light and resume light is blinkingc01576793.gif Solution one: Press the resume button
Load paper in the paper tray and press the resume button (c01219285.bmp ).
Try to print the job. If the issue continues, proceed to the next step.
Solution two: Clear the paper jam
Step one: Clear the jam from the back and top of the product
  1. Remove any paper loaded in the output tray.
  2. Turn off the product.
  3. Push the button on either side of the rear access panel or duplex unit and remove it. Figure 7: Removing the rear access doorc01576794.jpg
  4. Locate any jammed paper inside the product and pull it out towards you.
  5. If there is no jam, push the latch on the top of the duplex and lower its cover. Figure 8: Lower the product coverc01576795.jpg
  6. If the jam is there, carefully remove any jammed paper and close the cover.
  7. Replace the rear access panel or duplex unit.
  8. Open the top cover.
  9. Check for and remove any jammed paper by gently pulling it out.
  10. Make sure that there are no scraps of paper stuck between the rollers.
  11. Close the top cover, turn on the product, and resend the print job.
Try to print the job again. If the issue continues, proceed to the next step.
Step three: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Cause
The product might be out of paper or there might be a paper jam.
Feb 28, 2011 | Office Equipment & Supplies
Paper jam
If you are experiencing paper jam problem with your printer, please follow these steps: 1. Remove any loose sheets of paper from the input tray and the output tray. 2. Press the Power button (c01602202.gif ) to turn off the product. 3. Disconnect the power cord from the rear of the product. 4. Unplug the power cord from the wall outlet. 5. Turn the product around so that you can access the rear side. 6. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. 7. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. 8. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. 9. Remove any jammed paper from inside the duplexer. 10. Close the duplexer cover. 11. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. 12. Reconnect the power cord to the rear of the product. 13. Plug the power cord back into the wall outlet. 14. Press the Power button (c01602202.gif ) to turn on the product.
If you need any further assistance, please comment back.
Feb 13, 2011 | HP 8500 Premier All-In-One InkJet Printer
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
Paper jam problem
Remove the back cover and put an index card thru where the paper goes, that should push out any left over scraps.
Jul 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Seems to have frozen after removing a paper jam
Please explain: when you push the ON/OFF button:
1) the green light will go on and remain on or
2) it will blink and go off after a short time ?
In case 2), remove the rear door and put it again in place correctly (make sure it is well seated in place).
If the door is not installed correctly, the printer will refuse to switch on.
Oct 17, 2008 | HP DeskJet 1280 InkJet Printer
Lexmark x1185
It sounds like there is still paper inside. Remove all paper in the tray and if all is clear. Reload the paper and push the paper feed button. If this doesn't work unplug the printer on let it reboot.
Jul 31, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Dell 924 All-in-One InkJet Printer Logo
116 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
