Question about Acer Aspire 5100 Notebook
The keyboard does not work and the mouse
Suddently my computer turn off and we cannot use de keyboard and the mouse. Could you help me?
  • foopammy Nov 09, 2007
    My touch pad works fine and everything tests well but the keyboard refuses to work? any sugestions?
  • Anonymous Nov 12, 2007
    The keyboard does not work and the mouse problem, and notify you when a new solution is offered
Pressing the Fn key with the F7 key turn the touchpad on and off.
I was having the same issue with my tochpad and spent 4 hours taking apart and putting back together my 5100.
My touchpad now works like normal...
Hope this helps.
Posted on Nov 04, 2007
Suddently gone dark
Try to plug it in a different USB port. If the problem persist, try it on another computer or laptop. If it still makes the same problem, you will know it's because of the mouse.
Jan 05, 2014 | Microsoft Wireless Mouse 5000
It wont start working
Jan 05, 2014 | Microsoft Wireless Laser Mouse 5000
I have a Dell PC and I unplugged the mouse and the keyboard temporarily to clean it. When I plugged them both back into the tower and turned on the computer, neither one worked. I tried to restart, shut...
To try to resolve the issue:
1.) Will a different keyboard and mouse work (PS2 is the name of these connections)
If they will, damage to the keyboard and mouse is likely)
2.) Will a usb mouse and keyboard work?
If they do, then the problem is with the controller on the mobo, unlikley but MAY have been casued by static.
If the USB keyboard and mouse do not work, you have some problems with the motherboard
Try switching off and unplugging the computer, remove the coin shaped BIOS battery and plug in the keyboard and mouse, wait 2 minutes or so and put the battery back, replug in and power on, see if the bios detects the keyboard and mouse (you will see the bios screen flash up a message). If the computer does nOT detect the keyboard and mouse it will (or should) flash a message on the screen saying "no PS2 keyboard or mouse detected".
If this fails to detect the mouse and keyboard and you get no message or beeps, then there may be damage to the connector ports.
If you can get a USB keyboard and mouse to work, use them, Effecting a repair to the motherboard will not be a viable option
Jan 25, 2011 | Dell Dimension XPS 400 PC Desktop
I need to reset my wireless mouse and computer, but cannot navigate on the screen without these tools. Please help. :)
Turn the computer off. Find the reset button on the keyboard & the other on the mouse. Sometimes they list the button as "calibrate" or even "Sync". Some models require that you push both buttons at the same time and hold them down to reset them to working order. Others only have one button on the mouse or keyboard to reset the calibration.
Reseting the mouse and keyboard has nothing to do with the pc. You can reset them with commands from your computer.
After you push the reset buttons, turn your computer on and see if your keyboard and mouse are now available.
This should solve your problem.
Sep 27, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I have a wireless mouse. It is a Dell. has light...
Try to re-connect the mouse and keyboard using the connect buttons on the keyboard/mouse and the receiver to the computer.
Mar 01, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Microsoft Keyboard & Mouse not working
Hi there
Remember to check the batteries and press the connect buttons underneath the keyboard and on the mouse or mouse docking station
post back if no results
Kind regads
Feb 18, 2009 | Microsoft EF1330255 Keyboard/Mouse
Stoped functioning
Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
If your having trouble with the mouse also,
turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Dec 03, 2008 | Microsoft K5100141 Keyboard
Unable to start in Safe Mode with Command Prompt in XP Media Center 2005
Hi there. My name is Alex and I am here to help solve this problem
Depending if the BIOS has legacy USB support for keyboard and mouse enabled, you should be able to run safe mode by pressing F8 before the computer boots into windows. I would not recommend going into the BIOS if you do not have much knowledge to the computer as one wrong configuration could cause some behaviour problems or even damage to the pc's components
I recommend connecting a keyboard and mouse that have cable and the PS/2 connectors (purple and green) which can be found at back of the computer at the top. Then restart your computer, hold down F8 and you will be able to run safe mode. The mouse and keyboard will then work
Keep both the keyboard and mouse plugged in and boot windows. When you get into windows, plug in the USB keyboard and mouse into a USB slot and wait whilst it detects it. After a couple of minutes you should be able to use your USB mouse and keyboard and take out the PS/2 keyboard and mouse
I hope this has helped. Please let me know if you have any questions or need further assistance.
Oct 03, 2008 | Microsoft Windows XP Media Center Edition...
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Keyboard works but the mouse won't work (starlogic wireless optical set)
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jul 06, 2008 | Logitech EasyCall Desktop 967689-0403...
Acer Aspire 5100 Notebook Logo
261 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
