Question about HP Photosmart 2575 All-In-One InkJet Printer
The on switch keeps flashing,no function working, wont switch off
The on switch is flashing and it wont even switch off. none of the other functions work either.
    Guru:
  • 224 Answers
Make sure the printer is connected directly to the walljack without the surge protector and then unplug the printer while it is powered on(from the printer and the wall),wait for 30 seconds and then replug it and see if you get the same error.now if this still does not
work call up hp at 1800-474-
6836 and if ur printer shows
out of warranty in hp's
records dont worry ask the
customer representative to go
ahead and tell you the upgrade
options and go in for either
the photosmart 7280,photosmart
6380 or the photosmart 8180.
You will get it at a 50%
discounted rate.Its called a
refurbished printer but the
actual scenario is that if
wallmart purchases 100
printers and realises they
needed 99 they send one back
to hp and then our factory
test it before sending it out
to the customer but it has
never been used before.
trust me this is the best
option.I work for HP.
call in and hope you get me on
the call.If the printer is in
warranty then hp will try a
couple of troubleshooting
steps and if they dont work
then they will replace the
printer free of cost.
Posted on Jun 16, 2009
My tv won't take commands from my remote, it will shut down, but not restart
If you are using a none original remote then not all remote codes will work all the functions. Some codes are designed for different models. So you might have to try several codes before all functions will work. Even then some might still be missing.
If you are using a new genuine remote and it's still playing up. Then either two possibilities can occur. The set has been switched to work a different remote. Or there's a fault in the set that has either effected the remote functions or has caused the functions to cease to operate, even though the remote is sending out the correct signal and the set has received it.
Sep 25, 2016 | Insignia Digital-to-Analog Converter for...
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
Dryer that wont stop tumbling
Well we know the door switch is functioning properly so that usually just leave a timer issue.
Dec 05, 2014 | Dryers
On my 97 honda accord when the car is on and the lights are off everything flashes. The dash lights, the four ways, and every light in the car. When the lights are on tho it's ok, until you go to use the...
Your multi-function switch is likely toast and shorting internally. Removing the column shroud and inspecting the wiring will tell you if it's wiring. Given the fact the headlamps work but everything else doesn't suggests multi-function switch.
May 10, 2014 | Cars & Trucks
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Message Fan Check visible then 'protection' then powers off
my system keeps turning its self off then the standy keeps flashing...does any1 no why???thanks
Nov 20, 2011 | Audio Players & Recorders
My ti-89 keep repeating the same function ! no matter what i click, it came out the same function. The only way I can do is take out the battery. Otherwise, it just keep showing me the fame function.It...
If the calculator keeps showing you the same function, you can open the Y= editor and erase the function. To turn calculator OFF, press Diamond key then ON.
Feb 19, 2010 | Texas Instruments TI-89 Calculator
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
LG REMOTE WONT SWITCH FROM AM/FM TO DVD
HI THERE, I FIXED THE PROBLEM MYSELF BY KEEPING THE FUNCTION BUTTON ON THE DVD PLAYER PRESSED UNTIL IT FLASHED ""MODE"". THEN I PRESSED IT IN SEQUENCE TILL IT CAME UP WITH DVD/TV THEN IT AUTOMATICALLY SWITCHED OVER TO THE DVD FUNCTION MODE. ALL DONE. BUT THE TV/DVD BUTTON ON REMOTE STILL ISNT FUNCTIONING OR CROSSING OVER CHANNELL. HAVE TO DO IT MANUALLY VIA DVD PLAYER. EVERYTHING ELSE WORKING EXCELLENT. THANKS ANYWAY. HOPE THIS INFORMATION WILL BE OF USE TO YOU IN THE FUTURE. I CUD CHARGE YOU FOR THIS INFORMATION BUT I WONT THIS TIME.... LOL. MERRY CHRISTMAS AND GUDBYE...
Dec 13, 2008 | LG Televison & Video
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
HP Photosmart 2575 All-In-One InkJet Printer Logo
108 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
