Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Replacement of electrical cord
I am trying to fix/replace the broken electrical cord 0n this vacuum and read somewhere to take the long screw out and the handle should come off, but I have done that and NO LUCK with the handle coming off to get to the electrical cord behind the handle cover. Can someone help or have any ideas ? Thanks Richard
3 Suggested Answers
  • 97 Answers
SOURCE: Replacing the electical cord on Kenmore Progressive Vacuum
To the right of where the cord comes out of the machine is a large screw. Remove it, and slide the upper handle assembly free.
Then, on the front of the machine, remove the screws located toward the top of the vacuum just inside the bag chamber cover. This will allow the front panel to be removed, giving you access to the cord from the front.
-R
Posted on Sep 15, 2008
SOURCE: Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Posted on Mar 27, 2009
How do i replace the mains lead
replacement power cord (I'm hoping I'm reading a UK-to-USA transliteration of 'Mains Lead' correctly) can be found many places like Sears
Sears com or Amazon
1 Dyson DC07 DC14 DC17 DC18 DC25 Power Cord Compare to Part 905449 02... . My links have US type endplugs, if this doesn't reflect your location, amend the sources as appropriate. Rather than steal or borrow credit where due, you can see here on iFixit
Dyson DC14 Power Cord Replacement for what to take apart to swap the cord out. Needless to say, make sure you have the power disconnected from the wall before opening up anything on the vacuum (or any other electrical device). Good Luck!
Jul 20, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dog chewed the plug completely off my Bissell vacuum, model 61C5-W. Can I fix it myself, and where can I find the replacement cord?
The power cord should be a standard 3 wire cord. Any hardware store. Just buy the length you want. You will have to remove some covers/plastics to get to where the cord connects inside the vacuum. Look for screws holding panels in place. Once inside, you'll see how the cord is attached. Just replace the old with the new. Not critical which of the flat prong wires goes to + and - but be sure the ground wire (usually copper) goes to the ground screw and not a hot connection.
Oct 15, 2013 | Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
    you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
    Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
    I need to replace the power cord for my Bissell Vacuum
    Should be simple replacement. Once you have the correct replacement cord, just remove the cover, this only involves removing screws, trace the power cord to where is is connected. Once you have found it either write down where each color wire goes or undo one wire at a time and replace with new one. Should be simple fix...just take your time.
    Jan 28, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
    Ran over cord and the vacuum shut down, won't
    sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
    Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
    Need to replace cord on hoover u5720
    un do all screws on back of vac replace cord screw back together
    Feb 11, 2009 | Hoover U5720-900 WindTunnel Upright Vacuum
    Mrs Cleaner
    hi
    dsc04925t.jpg dsc04924t.jpg This should go without saying, but the first step is to unplug the machine. Next, open it up and remove the bag. Now you will need to remove the lid. There are white plastic clips on either side that you must carefully disengage by pushing them towards the center of the machine. Click the picture above and you can see that the right side clip has been disengaged. dsc04923t.jpg dsc04919t.jpg Once the clips are disengaged, the lid can be lifted clear of the body. Note the thin black plastic tabs on the lid that insert into slots in the body. Set the lid aside someplace safe where nobody will step on it. As an aside, I have twice replaced the dust channel, the fragile black piece of plastic visible at the top of the lid. Fortunately it is not a terribly expensive part and it is very easy to replace because it is only secured by four screws. Go back to the vacuum cleaner body. The next step is to remove the air filter. It is secured by two fairly obvious screws. These screws also hold down the switch assembly, which we will remove in the next step. But for now, go ahead and remove the screws and lift off the air filter. Put it aside where you won't lose it. dsc04915t.jpg dsc04907t.jpg Here you can see that the air filter has been removed and we are ready to remove the switch assembly. At this point the only thing holding the switch assembly to the body is the electrical connector underneath, and a plastic pin or two. Get a good grip on the switch assembly and lift it straight up with a firm but gentle tug. This is the underside of the switch assembly after it has been removed from the body. The white rectangular electrical connector in the center mates to the black rectangular electrical connector in the body, seen on the next picture. Put the switch assembly in a safe place until we reassemble the vacuum cleaner. dsc05469t.jpg dsc04910t.jpg Here we see the body with the switch assembly removed. We're almost there. The next step is to remove five screws, one of which at upper left is hidden in a deep recess. Click the picture above to see the location of these screws. The five screws have been removed. Carefully flip the vacuum cleaner over so that the black bottom and the wheels are pointing up. dsc04909t.jpg dsc04906t.jpg Here it is, belly up. Nothing is holding it together at this point, so just lift the entire base (the big black part) off and set it aside. It is not necessary to remove the rubber bumper that goes all the way around the outside of the base. As I learned the hard way, It is difficult to reattach. The inside of the base is likely to be pretty grungy. You could clean it up a bit with a damp cloth (I did), but there are wires in there so I wouldn't get it too wet. dsc04908t.jpg dsc04902t.jpg At last! The Miele's  innards are exposed. The motor is at the bottom of the picture and the cord winder is at the top. Remove one screw securing the cord winder electrical connector and then disconnect the electrical connector. You may now lift out the cord winder and replace it. I was also having an intermittent electrical connection problem which I thought was related to the problematic cord. It turned out to be an unrelated problem with one of the electrical connectors in the center of the machine, pictured above. Part of the plastic clip designed to hold the connectors together was cracked. Unfortunately I did not have a replacement part, so for now I wrapped some electrical tape around the connector to hold it securely together. This seems to have done the job. But the next time something else breaks on this Miele, I will order this part too and replace both at the same time. Follow the instructions in reverse to put your vacuum cleaner back together.I hope you found my little tutorial useful.
    Dec 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Problem starting
    This can happen if you have an intermittent short in your cord. Try plugging it in and then wiggling the cord around where it goes into the body of the vacuum with the switch set to "on." (If you're not sure whether it's on or off, just click it back and forth occasionally.)
    If the motor kicks on there's a short, which usually requires a cord replacement. If that's the case, it's a relatively simple fix for most dyson models.
    If not, you could have a short in your switch or somewhere else in the electrical system of the machine.
    -R
    Aug 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    How to replace power cord on Hoover WindTunnel upright vacuum
    The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
    Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
    Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
    Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
    Top Kenmore Vacuums Experts
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
