Question about Raven (Anglers International) Raven Vectra SST Series Center Pin Reels
How to take apart and clean a Raven Vectra SST reel
I got some sand in my Raven Vectra SST float reel I would like to take it apart and clean it
My daiwa sl50h have a grinding sound when you reel in any idea whats wrong.
Probably needs just a good cleaning and oil
I fish in a sandy beach area and when sand builds up in my reel it starts to grind, and sometimes it just needs an adjustment?
really hope this helps?
Mar 15, 2015 | Daiwa Sport & Outdoor - Others
Why is my reel able to reel both directions instead of locking in place?
Sounds like the slider switch didn't get back into it's socket properly, take it back apart and look at that.
Jan 31, 2015 | Abu Garcia 7000i RED Baticasting Reel
KVD Quantum kinetic PT baitcaster reel, problem is I took it apart to clean it and couldn't figure out the right way to put it back together with all the spacers please help
I know how much everyone loves those reels They are great when they are new. But the truth is They are made to sell and they do sell. But I will bet a dollar to a donut that You would have 300% less trouble out of a Shakespeare Reel with less trouble and 70% less on cost and you cant wear them out.
Mar 31, 2013 | Fishing
Inlet valve continues to let water in when door is opened and when the float is up
The needle in the water valve is not seating all the way closed. Some thing has gotten under the seat sand or limed build up. The valve will have to be taken apart and cleaned or replaced. In either case you will have to shut the main water supply to the dishwasher to stop it from letting water in.
Jan 21, 2011 | Kenmore Dishwashers
My 2 year old peen ss650 will at times reel in revers, the back stop does not always work.
Needs a good cleaning. Take it apart you will see trip lever clean and lube. If it is broken you will need to replace. I have done this many times and always say I will do it in Spring never get to it and have the problem when I'm in the suds
Nov 15, 2010 | Penn Spinfisher 7500SS Saltwater Spinning...
Carburetor adjustment weed eater fl sst 25,will only run if held 90% to the right.
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
Apr 22, 2009 | Garden
I'm trying to take apart this reel in order to clean and oil it. However I'm not able to remove the handles or the spool. Ideas?
Unless you know exacly what you are doing don't bother. It is a very complicated reel and expremely easy to put back together incorrecly. Send it off to Daiwa Sports service department. It'll either cost you £5 or nothing to have it serviced.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} T: 08450 603603
E: info@daiwasports.co.uk
Apr 19, 2009 | Watches
Raven (Anglers International) Raven Vectra SST Series Center Pin Reels Logo
Top Raven (Anglers International) Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Raven (Anglers International) Fishing Expert? Answer questions, earn points and help others
