Question about LG Televison & Video
Cable input stuck on dasdec login
My kid was trying to turn on the TV or so they say but when i get there its on a black background with a dasdec login prompt and i cant seem to get it to even attemp a login or come off
Benimur
  • 6966 Answers
SOURCE: cant get dvd to work
Hi, Do a hard reset. Unplug the unit for a couple of hours. Most current models will reset to default condition this way. If this does not correct the fault, pls post back with the brand/model/version of your unit. Good luck and kind regards.
Posted on Sep 22, 2007
  • 814 Answers
SOURCE: Picture appears neon and saturated/Video channels are white w/cascading black bars
This unit has had a problem with the mainboard of the television. This is the board that controls all the televisions functions.The problem you are having is with the tuner section of the mainboard, this problem may be a with cold solder joints from heat expansion or it could be a problem with component failure.The unit should be taken or sent in to a service center for a complete testing and service.The element customer support telephone number is 1-888-935-8880. The customer support website is http://www.elementelectronics.com/support.html Just tell them the model number of you television and the problem you are having with the tuner. They will be able to help you find a service center to take your television to for repair. I hope this information helps you with your problem.
Posted on May 29, 2009
  • 5 Answers
SOURCE: DVI warnings when you connect HDMI cables
TV IS IN DEMO MODE GO IN OPTIONS MENU OF VIDEO AND TURN OFF. READ OWNERS MANUAL PAGE 80,81,82
Posted on Sep 22, 2009
Bennytechkid
  • 99 Answers
SOURCE: My TV screen appears for a second then turns
If the tv isn't fully shutting down. but just flashing on and off then it
sounds like a backlight supply fault.
All LCD screens have what can only be described as micro flouro lights inside the screen module.
it is possible that the power supply is faulty causing them to flash on and off every now and then. or the tubes themselves are damaged.
to confirm this..
Lay the tv down flat on its back and power up in a well lit room
get down close to the screen and look across it at a acute angle
now if the black screen looks like it is still displaying an image then it's definatley your backlights!
in which case it could be a simple fault in the power supply.
so if your feeling confident in yourself i can talk you through what to look for in the supply..but try this first and get back to me.
hope this helps,ben :-)
Posted on Jan 06, 2011
welcomejee
  • 10594 Answers
SOURCE: cant get video 6 input. Seems to be stuck on
Please confirm tv model number as question shows it is Sony KDE-37XS955
Model number would be written on label pasted at rear of tv, this info will help me to provide you info about Video-6
Thanks.
Posted on Mar 21, 2011
I can't get the picture clear on my sharp aquos tv
Try using different input ports on the TV. Experiment with HDMI and component cable inputs if yu have a DVD player or cable box with those type of outputs
May 02, 2017 | Sharp Televison & Video
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
I cant get any of my inputs to change my kids hooked up the Xbox and now none of the inputs work for cable or DVD its just a blue screen with a no signal can anyone help me tonight please
Kindly check first if the batteries of your TV remote ( medium to change input ) are fresh. After that please check again the button on your TV remote for INPUT, SOURCE, or TV/VIDEO and it should give you input lists.
May 12, 2014 | Televison & Video
No picture but sound ok
in case you are using black background and while on video input mode,you have an open cable for vcr or any video inputs.if even you are viewing on tv programs,your tube might be busted or the series resistor from tube supply got busted also.sometimes,the high voltage to the flyback supply was dead thats why theres no screen light at all,that is depend on what model your tv is.
Jan 31, 2014 | Sony Televison & Video
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Nov 25, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Screen background flashes blue and picture flickers
the screen comes apart from the front bezel and back bezel. Try reseating the LCD cable. Reseat it behind the lcd and also reseat it where it connects to the motherboard.
The backlight is built into the screen so if reseating the LCD cable doesn't do the trick then that means the screen would need to be replaced.
Apr 28, 2010 | HP Pavilion dv9000t Notebook
Black screen in background television in background
You have to cycle through your inputs and find the corect input that you are hooked up to. Usually the TV/Video button or can either be called MLINK or Input
Feb 17, 2010 | Toshiba 50H81 50" Rear Projection...
Sep 22, 2009 | LG 32LH20 32 in. LCD HDTV
Televison & Video Logo
27 people viewed this question
Computer Repairing
Computer Repairing
