Question about Vitamix Blenders
Overload button The motor will not run
  • Vitamix Master
  • 1,631 Answers
Call customer service, or contact them:
Contact Us Customer Service Vitamix
Posted on Mar 16, 2015
Is my motor shot. Smells like electrical burning...
Probably. Motors will eventually burn out especially when they are overloaded.
May 15, 2016 | Blenders
Motor runs Blending spindle not moving
probably stripped the blender drive off the motor shaft
if it is still under warranty ,take it back
if not , with all the failing units you may get parts from the manufacturer
Jan 20, 2016 | NINJA BL770 Blender & Food Processor, Mega...
Replaced Capacitor and resistors motor running fine but cant keep the belt on keeps running off should rotation be clock or anti clock
Generally speaking, belt tracking issues are usually due to one or more of the shafts that support the pulleys not being perpendicular to each other - this applies to everything from treadmills to fan belts. Check and correct if possible: that the motor is securely mounted in the housing and that it is not installed crooked; and that the shafts aren't loose or have sloppy side to side movement. Belts should be tight - but not overly so.
Jul 22, 2015 | Kenwood Chef A901 901p 907 Quality Motor...
How to repair motor
If the motor is running then the fault must be with either the clutch on top of the motor or the blade clutch it engages with.
Aug 30, 2014 | Breville BBL600XL. 5-Speed Blender
KitchenAid Blender
The motor will probably be open circuit, take it back under guarantee and let them sort it out. If you mess around you will void your guarantee.
Aug 05, 2014 | KitchenAid Blenders
Ninja stopped working
Our Ninja 1100 also stopped during blending.
We set it aside and chopped manually.
Next day tried it again - it works.
Reason: motor probably has overheating protection. Must wait until motor cools down enough to re-start. So don't overload or overwork it.
Feb 27, 2014 | NINJA Blenders
Dissassemble
Assemble it with motor secure and base & feet on. Drill 3 or 4mm hole in edge of coupling Put screwdriver into hole on a large angle and whack the handle to undo the coupling. You are whacking it to turn in the same direction it turns when the motor is running.
Nov 20, 2013 | KitchenAid KSB560MC REFURBISHED 5 Speed...
When turning my Vitamix product on high it runs for about 45 seconds and then it shuts off. I then have to wait another 15 to 20 minutes before I can reuse the product.
It sounds like the motor is overheating, how long will it run with no beaker on it? If still 45 seconds I'd say new motor time. If it runs for 5 or 10 minutes then I would say replace the blade and bearing assembly in the beaker.
Aug 27, 2013 | Vitamix Blenders
Have had my Vita-mix 5000 for several years with no problems. Now, it leaks oily, black liquid around the base, and jerks erratically when the blender is set on the lowest setting (#1 of 10)/variable.
Is it getting hot when you operate it? If you run a mixer for a long
time, the motor will get very warm. On the older units, when the
motor overheats, the various parts of the motor and its container
may start to melt. Mixer motors are not designed to last forever and
a replacement motor may be available from the manufacturer.
Another way is to purchase another similar mixer as you can on
eBay and swap parts.
Aug 21, 2011 | Vitamix 5000 Work Top Blender
Blenders Logo
74 people viewed this question
Top Vitamix Blenders Experts
Holly...
Holly...
deton8 von Splosion
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
