Question about Ford Vehicle Parts & Accessories
2012 ford expedition rear fluid leak
Rear fluid leak
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Brakes, differential what
Posted on Aug 31, 2014
2 Suggested Answers
  • 194 Answers
SOURCE: The OEM pin stripe decals are peeling off my 2012 Ford Expedition ,should this be Warranty ?
If your under 36000 miles it should be
Posted on Apr 22, 2014
2012 ford ka-washer fluid entering cab when rear washer used
I think you need to remove some of the headlining to investigate the possibility of a leaking hose. The video of a Ford Focus may be some help
How to Replace Rear Screen washer Hose that is leaking 2001 Ford Focus
Apr 29, 2018 | Ford Cars & Trucks
How to open 1998 Lincoln Navigator it latch is broken?
Help:Navigator hood won't open - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Expedition & Navigator
Jan 30, 2012 - I have a 1998 Lincoln Navigator with a battery that needs to be jumped and I cannot .... I've accessed many broken hood latch cables that way. Rear liftgate and glass latch cables -1998 Expedition
Jun 1, 2012
Expedition hatch door doesn't open
Jun 20, 2011
need help replacing door lock actuator....98 Navigator
Jan 28, 2008
More results from www.ford-trucks.com
Sep 28, 2015 | 1998 Lincoln Navigator
Ford f-250 transmissiom leaking fluid
What's causing this transmission leak? - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 1999 - 2003 7.3L Power Stroke DieselJun 14, 2011 - I've never had a drop of fluid leak from my transmission until yesterday. I towed a very heavy ... 2011 Ford F250 King Ranch SB CC. Magnum ... 2002 F250: Transmission fluid dripping (pic)
May 29, 2012
leaking transmission fluid
Jan 6, 2011
Leaking Transmission (with pics)
Mar 23, 2010
ATF fluid leaking out of bell housing ?
Apr 6, 2008
Jul 14, 2014 | 2007 Ford F-250 Super Duty
Transmission not shiftin
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
TRANSMISSION GEARS SLIPPING AND FLUID LEAKING ISSUES
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These details will help.
Thanks.
Feb 15, 2013 | 2002 Jeep Grand Cherokee
Replaced 2 3 sol in trans goes forward in all gears
TRANSMISSION REPLACING AND TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
Thanks.
Dec 07, 2012 | 2005 Pontiac Grand Am
1986 olds 88 trans slipping
Transmission gear assembly and transmission needs inspection.Also check the transmission fluid level.Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot these problem.
2000 Toyota Camry: Transmission slipping and Stuck up? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping? http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem? http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating? http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Ford Windstar transmission fluid leaking? http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
Thanks.
Nov 24, 2012 | Cars & Trucks
Trans starting slipping after modulator replaced
Thanks.
Nov 24, 2012 | 1986 Oldsmobile Delta 88
My gear is not selecting after the drive.
For Automatic transmission problem,click the link below:----Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Why Transmission fluid leaks near radiator?
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 27, 2012 | 2005 Ford Taurus
97 ford windstar leaking transmission fluid
Possible leaks are 1. Transmission belly Pan gasket 2. Front pump/torque converter seal. 3. Transmission fluid cooler lines 4. Axle seals at right and left half shafts.
Feb 13, 2012 | 1997 Ford Windstar
Vehicle Parts & Accessories Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
