Question about Vehicle Parts & Accessories
Kawasaki mule 4010 gas, runs good most the time but occasionally will not rev. After stopping and pulling air filter, running a an idle for a while it starts to run fine again. Took to dealer and they
Mule is used for farm use.
  • 68 Answers
Check the fuel filter as well
Posted on Jan 24, 2015
2 Suggested Answers
  • 57 Answers
SOURCE: #1cylinder not firing on 2003 3010 Kawasaki mule
if its firing ok on other cylinders, unlikely to be pump or fuel filter, focus on electrics, plug, ht lead etc
Posted on Dec 08, 2013
What does the EPS stand for on 4010
Future tip, include FULL 'YEAR MAKE AND MODEL'.
The MULE 4010 Trans4x4 is built with reliable standard features such as selectable four-wheel drive, Electric Power Steering (EPS) system and a powerful engine equipped with Digital Fuel Injection (DFI®) that works in conjunction with a fully automatic transmission and locking rear differential.
2015 KAWASAKI MULE™ 4010 TRANS4x4®
https://www.kawasaki.com/Press/Release/2015-Mule-4010-Trans4x4
EPS stand for on 4010 Google Search
Oct 16, 2017 | Cars & Trucks
I have a 2003 kawasaki mule model 3000 it wont say running at idle what to do
Full tune up and carb clean .get new plug,air filter.oil Chang ,carb clean and adjustment.that should do it.,., try fuel filters and test fuel pump see if it's functioning properly.,.
Dec 10, 2016 | kawasaki 2005 Mule 3010 4x4
My 2003 Kawasaki prairie 360 when u install the hose from the air box it will only idle u can not rev it up take the hose off and it runs fine
2003 360 Prairie 4x4 cutting out... I'm stumped! - Kawasaki ...
www.kawasakimotorcycle.org > ... > Kawasaki ATV and Mule
Dec 14, 2011 - This 360 4x4 has me stumped. ... 2003 360 Prairie 4x4 cutting out. ....It idles just fine, it has perfect throttle response, it just won't rev without ... 2006 Prairie 4x4 governor prob?
Oct 1, 2009
04 Prairie 360 Knocking when Idling and Belt Light on.
Jan 26, 2009
Older Prairie Tune Up Questions
Sep 19, 2008
Prairie 360 (Limp Mode)
Jan 4, 2005
More results from www.kawasakimotorcycle.org
Nov 19, 2015 | kawasaki Motorcycles
Fan keeps running after switch off
does it ever shut off or will just run til doomsday. if it finaly stops then it probably working fine but if it never stops then you probably have a temp sensor gone bad.
Jul 06, 2014 | kawasaki 2014 Mule 4010 4x4
2012 kawasaki mule 4010 hitting on front cylinder only
First is the engine Diesel or Gas?
if it is a diesel engine it has almost got to be a compression or fuel problem if it is a Gas engine it can be a valve adjustment, fuel, compression, or spark problem
May 16, 2014 | kawasaki 2012 Mule 4010 4x4
Kawasaki mule 2012 4010 aftr running few minutes temp light will start flashing and efi light comes on then rpms just at idle
the thermastat is probly stuck shut replace it with a new one if problem still persist you may have engine damage aka cracked head ect
Feb 08, 2014 | Vehicle Parts & Accessories
2002 Kawasaki ZR-7S. wont rev up.
Check you main jets ccccccthey could need a good wiring through with needle wire cleaners or try running it without any air cleaner unit .If it runs well then could be an air filter problem.
Mar 13, 2010 | 2002 kawasaki ZR-7 S
I have a Kawasaki Mule 3000. It is hard to keep
take the spring off the screw and use teflon tape so you can adjust the screw further
Sep 11, 2009 | kawasaki Sport & Outdoor - Others
Mule 4010 cuts out when running about 3/4 throttle or more
Check for good fuel flow from carburetor end of fuel line. If no, check fuel tap filter screen inside of tap bowl.
Jul 11, 2009 | 1998 kawasaki KLX 300
Vehicle Parts & Accessories Logo
245 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
