Question about Kodak Office Equipment & Supplies
Kodak i620 I cannot connect via svt. Scanner appears to timeout.
2 Suggested Answers
  • 16 Answers
SOURCE: i have a Kodak i620 color. All of a sudden the red
What does the KDS Log say? find it in the SVT info tab and save it for more info. its probably your ultrasonic sensors dirty or faulty. good luck
Posted on Sep 24, 2009
Operation error when scanning
Ensure you have the most up-to-date drivers for your i1420: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Departmental/i1420_Scanner/Support/Drivers_And_Downloads/i1400_Series_Scanner_Drivers/index.htm Looks like v3.09 is the most recent. If you are unsure of your version, download and install v3.09, if your drivers are out of date, the install will update your drivers. Test the scanner using the Scan Validation Tool (SVT). This program should be located in the Kodak folder in your start menu. SVT will test the scanner's functionality at a basic level alleviating all third party software variables. Please consult your owner's manual if you are unsure how to initiate a scan in SVT. If the 1420 scans perfectly then you need to contact IRIS for support: http://www.irislink.com/c2-2365-189/IRISPowerscan---High-Speed-Scanning-Software.aspx
Mar 24, 2014 | Kodak i1420 Pass-Through Scanner
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
Xc timeout error
Did you find the solution of Xc timeout error ?? if yes please guide me also cause i also confronted with the same problem
Sep 13, 2013 | Toshiba Auklet CT Scanner
All application in my nokia e63 are working well except the phone web browser which keeps on saying web connection timeout
Its about operator service
how ever try to clear all caseh memory and then try
it also happens on particular websites
also check u connect via correct access point
Feb 14, 2011 | Nokia E63 Cell Phone
Can't turn off idle time out. and have to keep rebooding the router
Idle timeout is configured with the command
exec-timeout 0 0
The value is in minutes and seconds. If you put in a value of 0 1 then it will time out after 1 second of time. Idle time is configured separately for console and vty connections. One option is to connect via the console port and then change the idle timeout on the vty connections. If you have no access to the console port then you have to type fast or paste the proper commands in. You can type out the following commands into a text editor
config t
line vty 0 4
exec-timeout 5 0
end
You would want to copy them into your clipboad before logging into the router. Once you get logged in and into enable mode, you can paste the clipboard into the terminal (check your terminal instructions to find out how). This should set your idle timeout value to 5 minutes.
Jul 01, 2009 | Computers & Internet
I just figured out what you ment
Possible Cause Action
The SMTP server is not in
service.
Check with the network
administrator.
IP address of the SMTP
server is wrong.
administrator and enter the
correct IP address.
Port number is wrong.
correct port number.
A timeout condition occurs.
Set a longer value for “SMTP
Connection Timeout.” The timeout
value depends on the
network’s traffic conditions
and load on the FTP server.
The network is disconnected
during file transfer.
Send Ping from PC to the controller
and SMTP server to
check to see if both parties are
connected to the network or
not.
For any clarification on the procedures.
See “User’s Guide
[Network Scanner
Operations].”
Jan 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Time Out Error
This is from Xante's 3G Manual (downloadable via PDF)
"Printer Timeout The Timeout feature allows you to select the number of seconds the
printer waits for additional data before cancelling a job and returning
to the READY/IDLE state.
Set Timeout from the MISC:TIMEOUT configuration menu. The
factory default of 40 seconds (40 Sec) is an average setting. Set
timeout according to the type of files you send. Use a low setting for
small, simple files to prevent an indefinite tie-up on one job. Use the
300 or Never setting for large files, such as graphic intensive or CAD
(Computer Aided Design) files, to allow enough processing time.
With the NEVER selection, the printer does not timeout; it waits
until it receives additional data or until the printer is reset."
Here is the address where you can download the manual:
http://www.xante.com/support/aw3g/manuals/PDF/complete.pdf
Nov 15, 2008 | Xante Accel-a-Writer Laser Printer
Scanning drops in middle of scanning
Check to see if the computer has adequate RAM's installed to work with the scanner. Don't forget that in the background it is running scanner software, and the operating system at the very least.
It is also possible that there is a buffer over-run timeout error occurring with the USB port processing. There may be an IRQ address conflict. The over-run timeout error from the USB port may not be reported.
Try connecting a USB powered hub between the computer and the scanner. The powered hub will offer some isolation, and being a hub it has some internal memory with data repeating circuits. I have seen this approach fix a lot of problems with digital cameras and scanners.
If it still has the same fault with the hub, then try using the hub with the scanner on different USB ports. There may be an issue with IRQ's and addresses. Moving to a different port will sometimes allow for a different address for reading the scanner.
Past these options that I mentioned, the fault is very involved. If you do not have the in depth knowledge base about how to trouble-shoot this fault, you will have to get some assistance.
Jerry G.
May 02, 2008 | Umax Astra 2000U Flatbed Scanner
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
