Question about Kodak Office Equipment & Supplies
Kodak i620 won't connect
Cannot connect to svt
Kodak i620 elavator won't go up and down
What, exactly, is an elavator ?
Mar 01, 2017 | Kodak Cameras
Operation error when scanning
Ensure you have the most up-to-date drivers for your i1420: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Departmental/i1420_Scanner/Support/Drivers_And_Downloads/i1400_Series_Scanner_Drivers/index.htm Looks like v3.09 is the most recent. If you are unsure of your version, download and install v3.09, if your drivers are out of date, the install will update your drivers. Test the scanner using the Scan Validation Tool (SVT). This program should be located in the Kodak folder in your start menu. SVT will test the scanner's functionality at a basic level alleviating all third party software variables. Please consult your owner's manual if you are unsure how to initiate a scan in SVT. If the 1420 scans perfectly then you need to contact IRIS for support: http://www.irislink.com/c2-2365-189/IRISPowerscan---High-Speed-Scanning-Software.aspx
Mar 24, 2014 | Kodak i1420 Pass-Through Scanner
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
I620-auto feeding multiple sheet
I opened the hood on the machine, and between the first two intake rollers on the bottom, there is a small rubber strip. This strip comes packaged with a sticky yellow tape to protect the rubber. When it was installed, no one removed this tape. After doing so, the machine feeds great. Hope this helps someone else who may be experiencing a similar feed issue.
Jul 16, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
KOdak 2500 D -- cannot find target device
Go to Kodak's website and download the scan verification tool (the SVT), and see what it tells you. I use the 2500D with an Adaptec 2940 SCSI controller, and a 50-50 pin SCSI Cable.  I use the twain driver from Kodak's website and paperport 9 software.  This combination seems to work.
Jul 14, 2008 | Kodak Digital Science 2500D Path-Through...
49 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
