Question about Crosman Phantom Air Rifle Combo
Wont hold zero
The accuracy is no good large group sizes
What is the best load for your 168gr classic hunter in 308 win
Assuming that your Ruger has a potential for better accuracy (some guns just wont shoot any better than that) you'll have to work up a special load for the Ruger that will shoot more accurately.. What's good for one gun isn't necessarily good for another.. Also, in my experience, the Ruger M77 hasn't shown me much for good accuracy... I've seen some Brownings, though, that shoot very, very good...
Mar 17, 2014 | Retail Supplies
I need stella phoenix outlook pst repair product key
Helps to get back each and every inaccessible Outlook items such as emails, calendars, notes, tasks, journals, contacts, etc from Outlook personal folders and make them workable without loss any data. See at:- Outlook Emails Recovery
Nov 12, 2013 | Toys
For camping with large groups, what is the recommended stove?
The recommended stove for large group camping I advise you to purchase the liquid-fuel stove.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
How do I adjust accuracy, I think it involves the screw on the left side.
Accuracy is not adjustable with the screw on the side of the gun, that screw would be the velocity screw and should not be played with unless chronographing the gun to avoid setting it at unsafe velocities.
If you'd like better accuracy there are 2 upgrades you can make. #1 is higher grade paint. The more round and smooth the balls are, the more consistent and tighter the grouping will be. #2 is barrel. The closer the bore matches the paint, the more consistent and tighter the grouping will be also.
May 31, 2011 | Tippmann 98 Custom Act Paintball Gun
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
Just bought this scope and want to use on my rem 243,will it hold a zero once zeroed in?
The ability of a scope to hold it's adjustment is pretty much pre- determined by the quality of the scope itself...Better scopes hold adjustments better than cheap ones. Same goes for the mounts...a good mount will not loosen up or change point of aim.
If you are using a good quality scope and good mounts, once sighted in, unless you drop the weapon or have it shipped as 'baggage" on a long distance hunt, It should stay reasonably zeroed.
A 243 is not known as a "shoulder buster" so recoil should not affect adjustments.
243's are generally used in long range shooting. Therefore changes in temperature and normal use can change point of impact...so can changing the ammo you use. Therefore I don't recommend not checking accuracy before taking any weapon into the field. Wether you are using a $40 scope or a $1000 one, you owe the animal you are shooting, your very best attempt to take it down with one well placed shot. Checking zero at the anticipated shooting distance is the best way to insure that.
Dec 20, 2010 | Chevrolet 3500 Cars & Trucks
TV resistor mystery
Go to an electronics parts shop and take the damage resistor with you.
The bands are a colour code (the first two bands indicate the first two numbers, the 3rd one is for the number of zeros and the fourth one is the accuracy of the value e.g. 5%, 10%) for the value of the resistor.
The physical size of the component gives an indication of the current that it can carry.
Dec 19, 2009 | Washing Machines
Borland C array size limit
Hi , if you look at some of the postings you find the answer
http://bytes.com/groups/c/530395-array-size-too-large
Regards
Jul 26, 2009 | Computers & Internet
No pressure build up to make good coffee
Turns out it was just old coffee holding the group brewer together. Ended up replacing the whole handle which cost AU$44, so not too bad really. It's like new now.
Nov 25, 2008 | Saeco Magic Espresso Espresso Machine
Crosman Phantom Air Rifle Combo Logo
12 people viewed this question
Top Crosman Optics Experts
Martin Clarke
Martin Clarke
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
