Depending on the size of your home, a standard wireless G router should work the best.
http://accessories.us.dell.com/sna/productdetail.aspx?c=ca&l=en&s=dhs&cs=cadhs1&sku=A0589443&ST=pla&dgc=ST&cid=31209&lid=4865125&acd=1230881384347400
This is the one that I recommend you try first. Remember too, that with all electronic purchases, make sure you get informed about the return policy that way if a product does not work for you, you can always return it at try a different one.
SOURCE: Home network printing- How?
you can share the printer so that your laptop can use it also look in to adding your printer to the router so its on the network
SOURCE: cannot install access point dwl 2100
Visit the emulation wizard and simulate settings according to Quick Installation Guide
SOURCE: will my laptop router conect with nintendo ds lite
no way it is defrent but you can with flash
from nintendo or just set up the router to wep secure or open
SOURCE: problem using 2nd hand AP senao EOC3220 EXT
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
SOURCE: Please help me out in connecting two wifi routers
Hi there! Follow these instructions:
Place your TP-Link at the center of your business location for wi-fi easy-access for your customers.
Then connect an 8-port Switcher (HUB) in one of the 4 ethernet ports at the back of your TP-Link so you can use them for your hard-wire connections.
On your TP-Link, you still has 3 ports available and your customers can also connect to your wireless network easily!
Get back to me if you need additional tips!
^_^
