Question about Cretors Kitchen Appliances - Others
Heating element needed a heating element
    Habit-Forming:
    New Friend:
  • 67 Answers
Google Creators dealer. Most likely there will be one in your area?
Posted on Aug 03, 2016
Miele heating element
sorry - may seem odd - but your hot water tank is set to 120 or higher yes ? so why are you re-heating you water? - if you want to know you need the 2000w /230v - but really turn the re heat off - at 120 you kill the bacteria and will save $$
Mar 20, 2014 | Dishwashers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Tip
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
Element in oven sparked at corner and now will not heat
The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
Dishwasher is not heating water and wont dry dishes.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element for mineral deposit on it, clean the deposits using a soft brush and a cleaning solution (Don't scrub the element hard). If this doesn't resolves the issue then remove the panel and examine all the wiring connections to the heating element. Now, use a multimeter and check for the resistance reading (ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Dishwashers
I hav e an ADG7450.It will wash at 40 or 50 degrees but not at higher temperatures.Why?
Hi
Thanks
Daniel
Aug 20, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
Dryer not generating adequate heat. needing multiple cycles to dry. cleaned out the vent but no improvement. heating element??
I would check heating element also on the heating element box is a thermostat probably need to check that also take the wires off the heating element and use an ohm meter to check it out it should register and not go to infinity. Same for the heating thermostat.
Jul 15, 2010 | Maytag LSE7806A Top Load Stacked...
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Kitchen Appliances - Others Logo
124 people viewed this question
Top Cretors Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Cretors Kitchen Appliances - Other Expert? Answer questions, earn points and help others
