Troy 8150 Printer
I have difficulty getting the LPR command to work with Troy 8150 printer
This printer works fine in Windows as a network printer
I use the DOS command as follows -
Question - Do I need a -P (Print Queue Name) in the above command?
If so how do I discover what the Print Queue Name is?
Peter Byrne
RW Pierce , Dublin, Ireland
  • peter byrne Oct 31, 2007
    Have printed config, cannot see any print queue name on 2nd page.
    What header would it be on , ie Jet Direct Configuration, or Security Settings, or Network Stats, or TCP/IP ??
    Peter Byrne
  • 1,113 Answers
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S -P raw -o c:\temp\
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Posted on Oct 31, 2007
  • Soulvisitor
    Soulvisitor Oct 31, 2007
    Or have a look at print driver properties, ports, config ports
How can I upload the logolab.bmp from linux to the datamax I-4208 printer?
Assuming you want to print the file use the command "lpr" This is the only protocol used by this printer anyway.
If you have root access to the printer you can use "lp" but otherwise use "lpr"
command line usage:
"$ lpr logolab.bmp" please let me know if this helped or if I can clarify more.Joe
Feb 17, 2011 | Datamax I-4208 Thermal Label Printer
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
I want a printer driver for my Troy Micr 8150 secure Ex
go to
you should be able to get your drivers from there and its free to join.
Apr 30, 2009 | Troy MICR 8150 Secure Ex Laser Printer
sir i want to download hp lazerzet 1018 plzzzz help me
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
No access to the properties of the DP 8035 Panasonic running as an network printer on a MS SB Serversystem. Just the message: Spoolerservice is not running. I restarted the server, the Panansonic, the...
if driver is set up with a TCP/IP port reconfigured to LPR i suggest you try setting up a direct LPR port. you may need to add other network and file services through add or remove windows components, in add remove programes before you get the option in ports within your driver for a direct LPR port.
Hope this helps
Mar 20, 2009 | Panasonic DP-8035 Grayscale Copier
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
How to do rip and hold for 1r400
Command Workstation Use For Xerox Not For Canon. OK
Dec 12, 2008 | Canon imageRUNNER 400S Copier
Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Jul 28, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S -P lp text.txt"
Substitute for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
124 people viewed this question
