Question about LG WM0642H Front Load
How do I clean the steam or water spray nozzles. It does not spray out as it is washing I have a lg front loading washer
NOT SPRAYING DURNING WASH OR RINSE CYCLE
SOURCE: LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Posted on Dec 28, 2007
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
IFIXALL
  • 868 Answers
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Posted on Jun 09, 2008
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Posted on Jan 08, 2009
Can anyone help fix this washers spray function?
is it getting enough water in tub? try extra water button and see if then it works. if that makes it work, then water pressure sensor may be an issue
Apr 01, 2015 | LG WM-2032H Front Load Washer
What can be done to stop the orange steam nozzle/ water circulator on lg front load washer to stop leaking after wash is complete. machine is brand new
If you washer is brand new, call LG service. They will replace affected part at no cost to you under warrranty.
Feb 17, 2015 | LG Washing Machines
Nozzle blocked
this is easy job for you,,kindly removed all the lints from the nozzles with some metal peas ice...
Jan 30, 2014 | LG WM3875HVCA 4.8 Cu. Ft. Ultra-Capacity...
Washer wont wash-no water comes in washer
Your water valve inside the washer is either stuck, no water going to hose or the washing isn't sending voltage to open the valve. Start first by removing the hose. If water starts spraying all over the place turn off the hose and check for a blockage when it connects. Sediment may have clogged the screens there. More than likely a new water valve should take care of the problem. Sometimes sediment can pass through the screen and accumulate causing it not to open causing it to stick when voltage is applied as well.
Jan 16, 2012 | LG WM-2277HW Front Load Washer
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
LG Steam Washer
please give me some more details like model number. that will be easy
Apr 10, 2008 | LG WM-2277HW Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WM0642H Front Load Logo
14 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
