Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C 3201 bizhub c351
Tried a different fuser no help
  • Konica Minolta Master
  • 6,359 Answers
Did you reset the machine after installing the different fuser a different fuser does not reset the machine requires a manual reset procedure your old one might be ok just got to hot and shut down reset the machine.
Posted on Jan 13, 2016
Bubbabear64
  • 2794 Answers
SOURCE: Desktop faxing from Konica c351
Go to this link to get the fax drivers you need.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=827&filetypeid=0&osid=3
You should have had a cd that came with the machine that has them as well. Once they are installed, go into Microsoft Word and select the fax to print from. A screen should appear asking you for the phone number of the name out of the address book.
Posted on Sep 26, 2008
smt24
  • 54 Answers
SOURCE: put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
Posted on Jun 03, 2009
herminio_hal
  • 210 Answers
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
Posted on Jul 09, 2009
Kevin Hayes
  • 167 Answers
SOURCE: adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
Utility/Counter button
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
Posted on Feb 09, 2010
xeerie
  • 347 Answers
SOURCE: i have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
Posted on Jun 18, 2010
C351 konica does not print
does it copy??? try different file different program pdf, web page does it print the demo page does it print the counter page????
Apr 29, 2014 | Konica Minolta bizhub C351 All-In-One...
Black streaks
could be a bad black image unit, xfer belt or fuser
Jan 15, 2014 | Konica Minolta bizhub C351 All-In-One...
What is c-3452 error?
http://www.copytechnet.com/forums/konica-minolta/10478-bizhub-c351-error-c-3452-a.html
Fuser problem
Dec 10, 2012 | Konica Minolta bizhub C250 All-In-One...
Error message c3451
ok so this is a easy fix, if you have replaced your fuser recently then it may need reseated or just do a trouble reset. if you need help with that you can ask.
Nov 02, 2011 | Konica Minolta bizhub C351 All-In-One...
I have a konica minolta bizhub c351 How do I
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
Problem
You don't unless you happen to be a service technician.
The fuser is one place where you can get hurt playing around.
Also, most manufacturers will treat fuser id as a proprietary and you have to know the fuser id to change the data field.
Don
Feb 19, 2010 | Konica Minolta bizhub C351 All-In-One...
Minolta bizhub c 351 code c 3451
this error code means the fuser rollers failed to heat up you can reset the code by turning the machine off and hold down the utility\counter key while you turn the machine onwhen the trouble reset button shows on the touchscreen touch it and when it says ok turn the machine off then back on if the machine gives this erro again you will have to have the fuser replaced
Nov 19, 2009 | Konica Minolta bizhub C351 All-In-One...
Put in newer fuser unit but machine still says to replace
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
63 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
