Need to disable mouse on computer pad
To use remote mouse, I need to disable, mouse on computer.
SOURCE: Ps/2 compatible mouse disable
Press and hold 'Fn' and then press F7.
Hope that helps!
Posted on Nov 02, 2007
  • 40 Answers
SOURCE: I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
Posted on Sep 28, 2008
  • 8 Answers
SOURCE: LAPTOP BUILT IN MOUSE PAD
depending on what laptop you got i got an acer spire 5751z and it can enable or disable the mousepad by pressing 2 keys on the same time:
<FN><F7>
let me know what laptop you got or how it worked out
greetings
Posted on Jan 02, 2009
  • 162 Answers
SOURCE: lenovo 300 n200 disable mouse pad
Hi. I would suggest pressing the Num Lock key and see if it goes off, press and hold Function(Fn) button and hit the Num Lock key or press and hold the shift key and press the Num Lock key. Hope This Helps
Posted on Jun 08, 2010
immortal4u
  • 223 Answers
SOURCE: I can not disable touchpad
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Posted on Dec 30, 2010
I can't find any information re Windows CE. All I want to know is how to use the help page and how to disable the mouse pad.
Hi ms_k7582,
To "Disable" the Mouse Pad, or ("Pointer Device")!
Select the Control Panel, in the 'shortcut menu.
paul7of9_142.jpg Next, select the Device Settings, in the [Devices] block.
Click on, to "highlight the item you want to [Disable]."
The "Pointer Device, this will also 'Disable' the "Touch Pad"
Click the "Disable Button," just below.
"Always, ("click") on the, "Apply, and OK buttons before exiting."
*Note: Restarting the computer will configure system changes.
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!"
paul7of9
Mar 07, 2011 | Sylvania G-Netbook
When my new hp mouse pad locks, how do i unlock it without restarting the computer?
There should be a button above the pad or work your way using the keybord to mouse properties and go to the page that has the name of your track pad and select enable.
Mar 01, 2011 | HP Pavilion dv7-1020us Notebook
I bought an external mouse and now I can't turn the toutch pad off. It's becoming a pain for me when I'm typing. I did it once but I can't do it again. How am I supposed to go about disabling it?
Hellocrazybookworm,
To "Disable" the Mouse Pad, or ("Pointer Device").
  • Go to the Control Panel; select the (Mouse) in the Hardware and Sound category.
  • Next select the Device Settings, in the (Devices) block.
  • Click on, and "highlight the item you want to [Disable]" this being the "Pointer Device.
  • This will also "Disable" the "Mouse Pad."
  • Click the "Disable button," just below.
  • "Always ("click") on the, "Apply, and OK buttons before exiting.
  • *Note: Restarting the Computer, will configure "System" changes in the Computer.
  • To prevent errors from occurring. This is also important when, (Installing / Uninstalling) "Programs."
  • "To include (Enabling / Disabling) of Hardware."
    If this information helped? Return and give a "Helpful Rating," please!
    Thanks, paul7of9
Feb 23, 2011 | ASUS U52F-BBL9 Laptop
How do I disable the mouse pad on my ASUS K52F Lap top? I prefer the remote mouse but I keep touching the mouse pad when I type and the cursor just goes someplace else.
Hey man had the same prob but found how to fix it :). go to control panel click hardware and sound. then you will see devices and printers, under that will be, add device, add a printer, mouse. Click mouse! Then click the tap ELAN, there is a box to check, it says, "Disable when external USB mouse plug in". there you go. Hope that help.
Feb 17, 2011 | ASUS Computers & Internet
Have puchased. a acer wireless optical mouse how do I change over from the present mouse pad?
Theres nothing you need to do much, just plug in the wireless transmitter drive into the usb port, then download driver if one is required. Press the link button, usually a small button located under the wireless mouse.. then you should be good to go. You can disable the mouse pad, usually there is a button or a fn key to disable the mouse pad.
Jan 31, 2011 | Computers & Internet
My mouse causes me to have to gets in the retype all the time cause it goes back up in my sentence or highlights my words blue
This is a very common issue with mouse pads build into laptops computer and can be avoid by moving your hands away from the mouse pad (meaning to open more) during the typing process. You might also want to try to disable temporarily the mouse pad by pressing the mouse button sometimes located on top of your mouse cell or pad or, by pressing FN key along with "F's" key(from F2 to F12). There should be a pad with a hand meaning to either disabling or enabling your mouse pointer.
Finally, try to use and external mouse.
Good Luck!!
Jan 11, 2011 | Computers & Internet
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
How do you disable the mouse pad on an Asus using Windows 7 ?
To “Disable” the Mouse Pad, or (“Pointer Device”), go to the Control Panel; select the (Mouse) in the Hardware and Sound category. Next select the Device Settings, in the (Devices) block, click on, and “highlight the item you want to (disable)” this being the “Pointer Device, this will also disable the “Mouse Pad” Click the “Disable button,” just below. “Always (“click”) on the, “Apply, and OK buttons before exiting.” Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. “Did this solution help? Helpful Rating Feedback, appreciated, thanks paul7of9.”
Feb 09, 2010 | ASUS Computers & Internet
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
