Question about Third Party Snes Retro Duo 6ft Extension Cable - Retro Bit
Retro duo power supply needed
No power supply need to replace with the same thing
How do I hook up the Retro Duo nes/snes system to an older tv that has no a/v connections. I do have a Direct tv cable box but when I hooked the a/v cables to it absolutely nothing happened
Do you have a VCR that can hook to the TV that has the proper hook ups for your game system? Be sure your TV is on proper channel for your VCR to work (test it with a VCR tape and see if it plays) then change your channel on your vcr until it shows your game you have in your system hope that helps good luck
Dec 11, 2014 | Retro-Bit Retro Duo NES/SNES System Mascot...
What could happen with CD player switching on power supply 220v instead needed 110v?
Feeding it with twice the voltage it needs to work on?
In the best case, only a fuse has blown. Worst case? The whole power supply has had a to high voltage, before the fuse blew. All components will be aged and can give up in a few hours, after the fuse is replaced, or in a few months.
It also could be there are already some defect components in the player.
I wish you luck and hope only the fuse needs replacement.
May 25, 2014 | JVC Audio Players & Recorders
How do i connect retroduo to my tv
Most likely through a coaxial cable or RCA cables, it would be the antenna in to your tv or the RCA Video in and then tune the TV to channel 3. Unless this is a new system and uses
Oct 15, 2013 | Retro-Bit Retro Duo Twin Video Game System...
MA878LL iMac 24" core 2 duo 2.4 do not turn on,
Checking the power supply isn't the easiest thing to do, it involves pulling apart the entire machine.
You can try resetting the SMC, unplugging all power, hold the power button for 5 seconds, replace power, then attempt to turn on.
if it still won't turn on, and assuming you didn't get AppleCare or it is expired (past 3 years) it might be worth taking in to an Authorized Apple Repair Facility and see if they will check it out for free. If it is under warranty, most definitely take it in or call 1-800-APL-CARE
If neither of those are an option, Power Supply http://www.ifixit.com/Apple-Parts/iMac-Intel-24-Inch-2-4-2-8-GHz-or-3-06-EMC-No-2211-GHz-Power-Supply/IF169-002
a tear down from iFixit for the 20" model, it is most likely very similar for your model as well http://www.ifixit.com/Guide/Repair/Installing-iMac-Intel-20-Inch-EMC-2133-and-2210-Power-Supply/1006/1
Hopefully that helps. Good Luck
Feb 23, 2011 | Apple MA878LL iMac with 24" Screen Desktop...
Acer veriton m460 won't turn on fan runs that's it
Power supply failure. Replace it. Get 50+ more watts than the original. Power supplies are inexpensive and can be replaced without affecting your operating system or programs.
BTW: Many "failed" power supplies still can deliver enough power to spin fans and turn on the lights.
I recommend: www.newegg.com
If this helps please vote for my solution.
Jan 25, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
Games won't load - any sites taking in units and selling rebuilt?
Your best bet is to get a new system, but go with either the FC Twin or Retro Duo systems - they play both NES and SNES games problem free (with very few exceptions).  I personally recommend the Retro Duo.
http://www.google.com/products?q=retro+duo&a_n0=merchant_review&a_y0=3&a_f0=4&a_t0=5&a_o0=3&lnk=merchant_review
As far as trading in goes, can't help you there. But once you trade it in you can't go wrong with the RD.
May 26, 2009 | Nintendo Super NES Console
Both my FC Twin and Retro Duo (brand new) have issues with nes...
If it's a flat screen especially, there will be major resolution problems. I know the laser gun doesn't work at all on flat screens and some newer TVs. You gotta play NES on an old school TV any way. It makes the experience much more authentic.
Apr 13, 2009 | YOBO Fc Twin Console
Third Party Snes Retro Duo 6ft Extension Cable - Retro Bit Logo
Top Third Party Video Game Consoles & Games Experts
James Wishart
Are you a Third Party Video Game Console and Game Expert? Answer questions, earn points and help others
