Question about Asko Dryers
Asko Dryer TL751 XXLW turns black in back
Got an Asko dryer in Feb 09. Inside the unit there is a metal out vent in the back. It turned black and our clothes started to stink. 2 trips from service. Replace metal piece in the back. That piece turned black and then dryer took 2 times to dry cloths. Replace the piece again and thermostat. The metal piece turned black again after one load of cloths.
  • 116 Answers
SOURCE: dryer internal breaker trips
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
Posted on Mar 11, 2007
gotgeek2
  • 565 Answers
SOURCE: Dryer is not drying clothes fully.
As long as the dryer doesn't have electronic controls, this very common symptom indicates a bad(open) heating element.
Posted on Jan 25, 2009
  • 37 Answers
SOURCE: My Asko dryer does not dry clothes. It shuts off
It is quite common for lint to cover the blower on these units, making it impossible for the dryer to move any air.
1)remove the lower panel. you will need a T20 driver for this and may need to tip the dryer slightly to the rear
2)remove the left part of the blower plenum. this is held by 3 plastic tabs and a T15 screw
You will now see the blower wheel, it is a squirrel cage type. Check for lint buildup, broken vanes, or string/thread wrapped around the shaft.
if there is no problem with the blower then there is another reason you are not moving air. let me know if this helps
Posted on Sep 02, 2009
daddy1264
  • 76 Answers
SOURCE: gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Posted on Sep 16, 2009
Testimonial: "thank you "
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Mar 31, 2015 | Asko TL751 Electric Dryer
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
We just replaced the heat element still no heat any ideas
Contact asko... did you check the power going to the heating element. Or the control panel. If the unit doesn't know to work it won't I would check everything form the heating unit back
Sep 03, 2014 | Asko TL751 Electric Dryer
Is there a theromostat reset button on an Asko TL751 Electric Dryer
Have you clean the air vent out the one leading to the outside? One time we had one do the same thing because the vet was blocked it heated up to quick and sent the the message that the clothes was dry. I hope this helps
Sep 16, 2012 | Asko TL751 Electric Dryer
Dryer makes a grinding sound when stopping
I would try to listen to where the noise and smoke is coming from and get back. look here for some likely parts
Maybe the front bearing or rear bearing.
Apr 16, 2012 | Asko TL751 Electric Dryer
TL751 is two years old. Heating element burned
You did clean out the dryer before turning it back on?
May 10, 2010 | Asko TL751 Electric Dryer
Where can I get a parts list for an Asko TL751 dryer?
Try this website, I think they may be able to help you.
I hope this helps
http://www.partsselect.com/
Oct 03, 2009 | Asko Dryers
Asko dryer: room temp air, is not heating
first try the reset button .. a black rubber button at the back panel about middle...
Hope it helps if NOT let me know more about your problem... and I will help
Jul 02, 2009 | Asko TL751 Electric Dryer
Asko T700 Electric Commercial Dryer Problem
There's a reset button on the back of the dryer. It's a small black kinda rubber button about half way down the back panel near the center. push that button to reset it. should do the trick.
Jul 03, 2008 | Asko T700 Electric Commercial Dryer
Open Questions:
Dryers Logo
42 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
