Question about Rancilio Classe 6 E 2 gr Espresso Machine
Programed the machine and now espresso won't come out
I programmed the class 8 machine and now there is no espresso coming out. i push the button and it wont light up.
I am using a two group Rancilio Epoca espresso machine and would like to know how to set the water levels for the semi-automated buttons.
Hold down right most button for 8 - 10 seconds, then press button to program when you get your volume press button to stop repeat for next buttons, when done press stop button to get out of program mode.
Apr 19, 2011 | Rancilio Epoca ST-1 Espresso Machine
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
When pressing the hot water button there is only a limited amount of water coming out
Try reprogramming the button for a longer cycle. Hold stop button down for 5-8 secs and that should put you in program mode.
Apr 05, 2010 | Rancilio S24 Espresso Machine
How do i set/calibrate the shots on my la marzocco fb70?
Depending on model (yours might have a toggle switch to set it to program mode), hold down the continuous/stop button on the left pad all the lights will be lit after 5-8 secs, then push button to program get volume then push button again or stop button.
Dec 01, 2009 | La Marzocco FB70
I need a Push-button Panel With Tea-program for
Check with espresssoparts.com. They carry a wide assortment of parts.
Oct 26, 2009 | EXPOBAR Office Control Espresso Machine
Need to program stafco markus 2 group espresso machine
Normal you hold in the continuous flow button till all lights flash or stay on.
then you press the first button to program, once the right amount of coffee has come out press that button again.
Continue this with all buttons.
Please sign up to servicing program, we teach you how to service and maintain your machine. This will save you $$$ hundreds in service agent fees. We stock all parts.
Email me at sales@willisjococoffee.com.au
Apr 30, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Nuovo Simonelli VIP 2 group
Hold down the stop button and the continuous run button. lights will blink indicating program mode. Push one of the buttons that you are trying to program, when the desired quantity is reached press stop button. When all buttons are programed hit stop button again.
Jan 07, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Astoria SAE 2 Programing
The key is that you have to HOLD the programming button in for about 5 seconds before the system will go into programming mode. All the lights will come on and you will know you are ready to program the various shot buttons.
Nov 07, 2008 | Astoria Argenta SAE-2 Espresso Machine
Water flow
You will have to adjust your shot timing, and possibly your grind. To program the shot timing, hold the Brew Stop button until all of the brew lights come on; That means all of the buttons are ready to program. Next, pull some grind for your portafilter and push the button you want to program. For a single, you want to pull a 1 oz shot in about 15-20 seconds; longer for a double. When you push the button, the shot will start to pull; when the shot is complete, push the button again to set it. Then do the same for the next button. Each group needs to be programed separately. Holding the the Brew Stop button again will turn out the remaining lights and save your programming to that point. As to the grind, you want to have the grind fine enough to give you a quality shot in the right amount of time. Good Luck!
Oct 13, 2007 | Astra Mega II Espresso Machine
Rancilio Classe 6 E 2 gr Espresso Machine Logo
16 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
