Question about Dryers
Beko dryer drvs62w the drum is not turning the belt hasn't snapped what else could it be
The drum isn't turning the belt hasn't snapped what else could it be
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Hotpoint tumble dryer VTD001 (31330)
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Dec 27, 2010
jyackle5
  • 8197 Answers
SOURCE: I WANT A MANUAL FOR
Manual is on the link below.
http://www.beko.co.uk/manuals/DRVS62.pdf
Posted on May 19, 2011
  • 2468 Answers
SOURCE: once i have replaced a
do you have it routed around the belt tensioner pulley correctly? if its loose its not routed correctly
Posted on Jul 18, 2011
SOURCE: I HAVE A TUMBLE DRYER
If the drum won't turn manually, the problem is probably the front drum seal. When it wears out, the drum sticks and the machine will chew straight through the drive belt.HTH
Posted on Dec 27, 2011
Hi I'm getting no heat from my beko drvt 61 w tumble dryer, have replaced the front thermostat, heating element and cleaned filter at front but still no luck is there any more I can do?
Did you check fuse that might be near mains entry into the machine ? Why did you replace the heating element ?
is rest of machine working ?like fan motor running ?
sens more details so that I can pin point the trouble.
Oct 03, 2015 | Beko Official Drvs62w Belt Poly V - 1967...
**** beko dryer drvs62w
hiya my beko dsc85 8kg has stopped after finishing a cycle of clothes but wont restart just says drying but nothings happening and i have cleaned everything twice any advice on the problem would me much appreciated. thanks glenn
Nov 15, 2012 | Dryers
WIRING DIAGRAM BEKO DRVS62W
Hi i took the front pannel of my beko drvs62w dryer to replace a button and for gote what colour wire gose where on the bk of the power button can anyone help please
Nov 09, 2012 | Dryers
I HAVE A TUMBLE DRYER BECKO DRVS62W THE BELT HAS SNAPPED HOW DO I REPLACE IT. THE DRUM DOES NOT ROTATE MANUALLY IS THIS ANOTHER PROBLEM OR WILL THE DRUM ROTATE ONCE THE BELT HAS BEEN REPLACED.
If this is an electric tumble dryer,
the way to replace the belt is from the rear of the machine,
remove all the screws on the rear silver panel, which gives you access to the internals of the dryer.
And yes the drum wont turn properly if the belt is broken.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Dryers
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
DRUM NOT TURNING ON BEKO TUMBLE DRYER. JUST OUT OF WARRANTY.
Check your drum belt, sometimes this belt is broken or slipped off the motor pulley or idler arm pulley.
Also could be a faulty motor..
Another thing to try is to turn the drum by reaching inside of the drum and turning it by hand 1/4-1/2 turn with the dryer off. Then turn the dryer on again and see if it works.
Motors will sometimes get a dead zone in them and this help move it from the dead zone.
Sep 26, 2009 | Dryers
Dryers Logo
Top Dryers Experts
