Question about Panasonic KXDT343 Phone
On my kx-dt343 I need a second extension to ring on incoming calls
Only the receptionists phone is ringing when someone calls, but there is not always someone at her desk, i need the phone to ring in my office as well. How do i do it?
cnavarro
  • 2460 Answers
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
Posted on Sep 04, 2008
cnavarro
  • 2460 Answers
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Posted on Sep 09, 2008
SOURCE: Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
Posted on Oct 19, 2008
cnavarro
  • 2460 Answers
SOURCE: I want to pick up incoming calls from another extension
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
Carl
Posted on Nov 18, 2008
SOURCE: I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Posted on Jun 24, 2009
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
How do I set the extensions for the nightbell function on the KX-DT343?
Ringing is controlled by an ICD group. You can do it from the control phone, but I wouldn't. Better to call your installer/dealer/service tech and have them do it. In programming from the console it's program 620 and 621 IIRC (that or 621 and 622)
Carl
Mar 13, 2013 | Panasonic KXDT343 Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Incoming calls goes to voicemail, then to receptionist. Also rings at three extensions at the same time.
It sounds like all the incoming calls are going to a hunt group. This would explain why three extensions ring, then it goes to the receptionist, and then ends up in voicemail.
Try looking for a hunt group that distributes to the three extensions in question, or that only has those 3 extensions active.
Dec 10, 2010 | Avaya 4610SW IP Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Everytime that anyone calls the receptionist, her line is busy, How do I correct this issue? Thank you . Panasonic KX-T7630
A couple of ideas. Have the receptionist call you and verify that they are really at the extension you're calling. Then make sure you turn on Call Waiting Intercom on that phone. From the intercom on the reception phone, dial *7311 for Intercom and *7321 for Outside lines.
Now the phone will soft ring and visual indication when you get a second call if you're phone is busy.
If you've mapped a button to ring the receptionist and it's not working, you may have unprogrammed the button. That's reprogrammed by PROGRAM, the button and 1 plus the extrension (usually 101) and STORE or ENTER to save. PROGRAM exits programming.
Carl
Jul 22, 2010 | Panasonic KX-T7630 Corded Phone
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Carl
Nov 18, 2008 | Panasonic KX-TA308 Phone
www.heymot.co.uk
Oct 17, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KXDT343   Phone Logo
21 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
