Question about GPX Boombox BC112B
The boombox hums when plugged in.
It doesn't matter if the volume is up or down, the unit outs out a loud hum when ever it is plugged in.
KLH HPS 1100 powered subwoofer. as soon as plugged into AC we get a loud hum from spkr. had unit for 8yrs.
Hum usually indicates a power supply problem. If it has an internal supply you will need someone to check it's producing clean DC. Alternatively if you do open it (beware risk of shock!!) initially visually check condition of /replace any bulging electrolytic capacitors.
Jun 27, 2014 | Audio Players & Recorders
Loud HUM from 1963 Wurlitzer 2710 when plugged in
If you observed a vacuum tube with the symptoms you describe, it requires replacement but there may be other failed components as well.
Dec 27, 2013 | Audio Players & Recorders
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
Benwin 5.1 surround sound system Humming loudly without anything pluged into it!!!
It is sad your having a problem with your
If humming can be heard on all speakers, then it could probably
be on the power supply.
If it is only on the main SUB unit, then it could be the amp itself.
But check for power supply capacitors that supplies voltages to the
amps.Check for amp output DC voltages too.
Oct 04, 2012 | Audio Players & Recorders
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
Apr 12, 2011 | Samsung HLS4676S Television
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Motor making loud humming noises and kicks out. Could this be a capacitor on the motor going bad ? This doesn"t happen all the time, but frequency is increasing.
this is the motor overheating and, the overload shutting down the motor: check to see if the motor belt is binding
Jan 23, 2010 | Washing Machines
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
GPX Boombox BC112B Logo
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
