Question about Gateway XHD3000 LCD TV
Strobe-like flickering in upper half of Dell monitor
This is a Dell LCD, 17 inch. The stobe is intermittant and usually only affects the upper 1/3 to 1/2 of the screen. Does anyone know of a repair for this?
    Problem Solver:
  • 5 Answers
The problem is the inverter on your dell monitor this is very comon.
Posted on Sep 01, 2009
My dell moniter 2010f flickers all the time. I have another moniter on that uses the same card by does'n flickers. I also pugged the dell in by its self and it still flickered. l also down loaded...
Sounds like an issue with the backlight in the monitor. Usually the backlight is built in to the LCD panel so there really isn't a way of fixing this unless you replace the panel.
Please rate my solution to show your appreciation!
Jun 02, 2011 | Dell ST2010 20 inch LCD Monitor
17" flat screen upper half is dark until "thumped"!
The inverter board that controls the lighting on the screen is dying. since its a 5 year old monitor and only a 17 inch. the cost to repair is greater than the cost of buying a new one. unless you know how to replace the part yourself. I think its best to just buy a new monitor
May 04, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
My HP Compaq LCD Screen (17 inches) has intermittent or no video
ur vga cable may be defected 100% chance for cable or tft screen may be
my email sushilverma150@gmail.com
Mar 24, 2010 | HP Compaq FS7600 17" CRT Monitor
Had my monitor for four years, great performance
jlallen54, When lcd panel goes to a dark condition please shine a bright flashlight 1 inch from screen an tell me if screen data is still displayed during this "blackout" condition. It might be just a single (1) poor and now thermally intermittant solder connection on the printed circuit board inside the monitor. Do some reading first and then you will understand the problem that your monitor has. 12fixlouie
Jan 17, 2010 | Sony SDM-HS73P 17" LCD Monitor
My hp vf15 monitor flickers on and off when it is plugged
17-inch CRT?
Ask your friends -- one of them probably has a "surplus" 17-inch CRT that they will _love_ to give-away to you, to replace yours.
Or, look on CRAIGS LIST for a used 17" LCD screen, for $30 to $40.
Jan 14, 2010 | HP Pavilion MX75 17" CRT Monitor
Monitor flickering
Monitor flickering can be one or several problems.
Depending upon the age of the unit and value, you should decide weather to repair it or replace it.!
More than likely, it is a problem in your power supply.
The capacitors in the supply will leak and most often crown.
If when you start unit after sitting for a while, it shows good and then after a few minutes it starts flickering, you can bet it is one or several capacitors in the supply.
This monitor is a 17 inch and not really worth the time and investment to repair, unless you have the technical skills to remove and replace electronic components.
Nov 05, 2009 | AOC 177Sa 17" LCD Monitor
Bluish green screen on dell laptop
It might be that your red pin is bent out of shape. Please make sure ALL pins on BOTH ends are straight, and none are broken or missing. Also, make sure that they are firmly secure.
Jul 03, 2009 | Dell E176FP 17" LCD Monitor
My Dell E172FPb flickers & has straight, thin
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
Jul 02, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Gateway XHD3000 LCD TV Logo
318 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
