Question about Amana ARGS7650SS Gas Kitchen Range
Amana arg 7800 oven will not heat
We turn the oven to 350 and it stays at 100 degres
  • 71 Answers
SOURCE: My oven take to long to preheat
this is most common is low voltage caused by a bad connection . The most common place is on the terminals of the bake element.
Posted on Dec 13, 2008
crayzeetrayn
  • 837 Answers
SOURCE: temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Posted on Feb 08, 2009
aborcass
  • 2651 Answers
SOURCE: oven does not heat up - occasional gas smell
you have bad ovne ignitors( bake iginitor is no good
Posted on Mar 19, 2009
SOURCE: Describe your amana arg7800ww Gas Kitchen Range
can't get the oven to go on to bake. can you help me solve this problem thank you.
Posted on Feb 22, 2011
  • 794 Answers
SOURCE: my oven will not stay on .F9 code appear whats the problem?
Hi healinghe445,
It has something to do with a motorized door if you are getting this error code F9. The most common thing that needs to be checked is the latch. If you find it faulty you will need to replace it with a new one. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 09, 2011
Set oven for 350 degrees but won't heat stays at 100 degrees but the broiler works
you will need to check the oven probe replace it if needed,if that does not solve your problem then your will ned to replace the electronic control board if equipped
Dec 21, 2010 | Kitchen Ranges
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
Mar 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
Temp stuck on 100 degrees
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Oven does not heat up - occasional gas smell
Jan 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Jan 03, 2009 | Thermador C302U Electric Double Oven
The bake element is probably defective or has a burned wire on one of the ends.
Dec 13, 2008 | Amana AER5715QAS Electric Kitchen Range
Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
Dec 09, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
22 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
