Question about Curtis RT700 7 in. Portable Television
Change mode input
Don't change the input mode, from SVHS to Antenna, I need know can change it.
How do I change from cable to antenna?
Without knowing the make and model it is difficult to answer your question accurately. In general you would change either the source or input option. Usually the antenna option is called TV.
Sep 08, 2015 | Televison & Video
How do I set up my viore TV for antenna TV ?? All I am getting is NO SIGNAL? I have no book with the TV
See if there's an input mode button. If so then that should allow you to change the mode to antenna.
Jun 17, 2015 | Viore Televison & Video
How do I change from cable to antenna input
Its in the menu for the set--on screen and is done with the remote---you want to move to antenna/air.
Even if in cable mode it should pick up any active channels 2-13.
Dec 03, 2012 | Insignia 32" 720p Flat-Panel LCD HDTV
I don't want to use the antenna on my Sanyo Ds20930
You have to enter its service mode to rectify this problem. Just contact any expereinced tech, as this is a very risky and skilled work. The tech know, what to do.
May 22, 2012 | Sanyo DS20930 20" TV
Cant change the input mode on my LG 50pq60d. its in antenna mode and will not change to av
I think this calls for a phone call to LG customer service to see what can be done and to inquire if this is known issue in this model--all these companies keep extensive records or model versus problems.
May 01, 2012 | LG 50PS60 50 in. Plasma HDTV
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
Why is my playstation 2 in black and white? I have changed av cables, different video inputs, also swapped dvd player with ps2 video inputs. The dvd player is still in color? is there something with the...
For me it sounds like the TV treats the incomming signal as a SVHS signal. I have had the same problem with a SEGA dreamcast back in the days. In my case it was a quite simple setting in one of the TV menus.
Try different video inputs. (and SCART adapters) This is also is a important step. Some older TV's doesn't have SVHS support at some of the SCART inputs, and in your case that will be a good thing.
But as you said, you maybe already have tried this.
Don't know if this was any help for you but i wish you good luck!
(Because PS2 is still really fun playing)
Oct 10, 2009 | Sony PlayStation 2 (PS2) Console
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
Curtis RT700 7 in. Portable Television Logo
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
